Vote here - 2019 Guitar of the Month Runners-Up Contest!
Which guitar should win the December 2019 Guitar of the Month Contest?
  • Total voters
    46
  • Poll closed .
GOM
December 2019 Guitar of the Month contest!
This is a special Runners-Up contest for all those who just missed out on the top spot - some in a very close shave! The winner will qualify for the 2019 Guitar of the Year contest coming up in January!
As usual, discussion about the submissions can take place below.
Please do not post replies that show additional photos of the entrant's guitars, but links to other UnofficialWarmoth threads or external sites are fine.
Good luck, and may the best guitar/bass win!
February
Guitar #1 Celtikaos
Body:
Warmoth chambered Telecaster
Left-handed
Roasted swamp ash on black korina
pickup route: humbucker,none,tele
Bridge: Tele bridge
contours: tummy cut, contoured heel, forearm contour
Finish by MJT in closet clean shoreline gold with checkings
Neck:
Warmoth Modern construction
Neck wood: Wenge
Fingerboard wood: Figured Ziricote, unique choice FB2805
Nut width: 1-11/16
back shape: SRV
fret size: SS6150
Radius: 10-16 Compound
Pre-cut installed string nut: Graphtech black TUSQ XL
Inlays: cream face dots
Side Dots: White side dots
Pickups:
Bareknuckle Flat 50 Tele bridge
Bareknuckle The Mule humbucker neck
Hardware:
Gotoh mini locking tuners
Gotoh 6-saddle LH Tele bridge
920d prewired plate with concentric pots and split for neck pickup
Mint pickguard
Graphtech black TUSQ XL string trees
March
Guitar #2 stratamania
Natural Ash Tea Stained Tele
Construction: Solid
Neck Pocket: Tele® Shape
Wood: Extra Light One Piece Swamp Ash
Orientation: Right handed
Control Rout: Top Rout
Pickups: T-X-T
Bridge Rout: Tele® Bridge
Input Jack Rout: 7/8" (22mm) Side Jack Hole Jack
Scale: 25-1/2"
Weight: 3lbs., 11oz.
Wood: Birdseye Maple Neck Wood/Indian Rosewood Fingerboard
Orientation: Right Handed
Nut Width: 1-5/8"
Nut: Graphtech XL Earvana
Back Contour: 59 roundback
# of Frets: 22
Frets: 6100 SS
Radius: 10-16" Compound
Inlay: Cream Face Dots
Side Dots: White Side Dots
Scale: 25-1/2"
Finish
Body: Satin Nitro, with Tea used as a stain for the One piece Ash Body.
Neck: Headstock Satin Nitro and Neck Shaft Tru Oil.
Both Finished by myself.
Tuners: Hipshot Open Gear Locking Tuners
Pickups: Seymour Duncan Vintage Noisless, 4 Way selector and powerboost wiring.
Bridge: Gotoh.
Dunlop Dual Design Strap Loks
Guitar #3 new-killer-star
This is my warmoth jaguar which is setup halfway between a jaguar and a jazzmaster. I've gotten rid of the jaguar switches and replaced them with a modified jazzmaster wiring with series / parallel switching and PTB tone knobs.
Body:
Swamp Ash showcase body
Simple 2 color dark / light wipe on finish
Neck:
High Grade flame roasted maple neck from showcase
Sperzel open back locking tuners
6150 SS frets
Hardware + Electronics:
Righteous Sound Ninja 90 (noiseless p90)
Rothstein STB super mod jazzmaster wiring harness: series/parallel switching dual volumes and PTB tone modified to fit in a jaguar
Stainless steel pickup selector
Pearloid warmoth pickguard
Mastery Bridge + Tremolo
April
Guitar #4 RoboNarples
Body:
Model: Chambered Carved Top Regal
Scale: 25-1/2"
Wood: Flame Maple / Maple on Mahogany
Rout: Rear Rout
Bridge: TOM/STP, Angled Pocket
Neck Pocket: Strat® Shape
Contours: Contoured Heel
Binding: Ivoroid Binding
Top Finish: Tropicana Tilt Fade
Back Finish: Clear
Finish Type: Gloss Finish
Neck:
Style: Stratocaster
Construction: Modern Construction
Neck Wood: Quartersawn Goncalo Alves
Fingerboard Wood: Goncalo Alves
Nut Width: 1-11/16"
Back Shape: 59 Roundback
Fret Size: 6150
Tuner Ream: Gotoh/Grover (13/32" 11/32")
Radius: Compound
Scale: 25-1/2"
Fret #: 22
Pre-Cut Installed String Nut: GraphTech Black TUSQ XL - Standard Nut
Inlays: Cream Face Dots
Finish: None
Hardware:
Neck Pickup: EMG 81
Bridge Pickup: EMG 85
Bridge: Gotoh Tune O Matic Bridge, Chrome
Stop Piece: Gotoh Stop Tail Piece, Chrome
Tuners: Gotoh Magnum Lock Traditional 6-In-Line
Guitar #5 Robin Joseph Leon
Warmoth Telecaster Thinline 72 body
Routed for middle pickup,dual input and battery box myself
Flame Maple Top
Mahogany body
Tigers Eye dye finish
Tobacco Burst back finish
Natural Masked binding
Graphtech piezo saddles
Warmoth Modern Stratocaster maple neck
Wizard Thin shape
Clear Satin Nitro Finish
6105 frets
GraphTech Black TUSQ XL nut
Black dot inlays
Chrome Fender Locking tuners (with brass bushings)
Selfmade black matte HSS ’72 Thinline pickguard
Seymour Duncan JB Trembucker bridge pickup
Seymour Duncan Classic Stack plus middle pickup
Seymour Duncan Duckbucker neck pickup
6 (!) way Oak Grigsby switch (added lowest setting is bridge + neck)
2 Fender TBX tone pots, one wired to neck and one to brigde
Push/Push volume pot for series/parallel neck
Built in Seymour Duncan triple shot for bridge pickup
Dual inputs, one for piezo, one for electric signal
Schaller strap locks
Hybrid hardware
May
Guitar #6 Vallhagen
Neck:
Warmoth, Ebony on Goncalo Alves
Modern construction.
Routing for locking nut and headstock shaping (it was a strat head) by myself.
Compound radius, 6130 frets.
Body:
Warmoth Velocity
Alder
All body contours.
HSS routing
Trem routing by myself.
Pickups:
Lundgren Black Heaven bridge HB
Lundgren vintage 60-s middle and neck SC-s
Tremolo:
Kahler 2710 "Killer"
Locking nut from ebay
Pickguard:
My own design
Finish (body and headstock):
Belton spraycans; red(!) and clear.
Guitar #7 Dano
George Harrison Tele Look-alike (almost)
Rosewood Telecaster Body
-Rosewood with Maple center laminate body purchased from an individual in Brazil.
-Rough Finish and Routing by seller of Body.  Final sanding from 320 grit down to 0000 synthetic steel wool by owner.
-Finished by owner with multiple coats of hand rubbed Tru-Oil.
-Sanded / polished with sandpaper all the way down to 0000 steel wool between coats.
-Black 3-Ply Nylon Pickguard
Warmoth Indian Rosewood neck
-24-3/4" Gibson Scale Length Modification
-Modern Construction Neck (Truss Rod)
-6150 Jumbo SS Frets
-10" - 16" Compound Radius Neck
-Graphtech Black Tusk Nut XL Standard Nut
-Grover 505C 18:1 inline Locking Tuners
Electronics, etc.
-Seymour Duncan Lil' 59 Bridge Pickup
-Seymour Duncan Quarter Pounder Neck Pickup
-500k CTS Volume and Tone Potentiometers
-Russian PIO (Paper in Oil) 0.022uF Tone Capacitor
-Oak Grigsby 4-Way Blade – Bridge, Bridge + Neck, Neck, Bridge and Neck in Series)
-Switchcraft Output Jack
-Gotoh GTC202 Telecaster Guitar Bridge Tele Steel Saddles w screws - CHROME
June
Guitar #8 Old Яomans
Warmoth All Goncalo Alves CBS Modern Neck with Tusq nut and SS frets (Finished by Warmoth)
GFS Body and Surf 90's Pickups
(Body came finished in Mary Kay White with Gloss Clear)
Custom Goncalo Alves 'Mosrite-style" Pickguard; owner finished in Tru-Oil
Custom Goncalo Alves Rear cover with magnets; owner finished in Tru-Oil
Custom Maple Veneer Logo
Wilkinson hardware
Fender Vintage '65 knobs
July
Guitar #9 dawidge
Fretless Dinky J
Body
Model: DinkyJ
Finish: General Finishes Orange Dye/Ebony Grain Filler/Minewax Wipe-on Satin
Wood: Swamp Ash
Bridge - Hipshot Kickass
Tuners - Hipshot
Pickups - EMG JHZ (passive)
Neck
Style: Jazz Bass
Construction: Vintage/Modern Construction
Neck Wood:  Quartersawn Brazilian Ebony
Fingerboard Wood: Ebony
Nut Width: 1-1/2"
Back Shape: Standard
Frets: Lined Fretless
Tuner Ream: BML
Radius: Straight 10"
Fret #: 21
Finish: No Finish
August
Guitar #10 BigSteve22
CasinoCaster, "Amy"
Body:
Mooncaster, Showcase # MP619
Flame Maple on Mahogany
Vintage Tint, Gloss
Rear Routed
2x P-90s, 2x Tone, 2x Volume, 1x 3 Way Switch
Strat Shaped, Angled Neck Pocket
Contoured Heel / Tummy Cut (Both Standard)
Drilled for Gotoh 510 Bridge
Neck:
Custom Built
24.75" Conversion Scale, Warmoth Tilt Back, 3x3
Standard Thin Profile
Black Ebony on Roasted Flame Maple, Unfinished
White Pearloid Trapezoid Inlays
Strat Heel, 4 Hole Mounting
10"-16" Compound Radius
22,  SS6230 Frets
1-11/16" White, Tusq XL, Nut
White Pearloid Trapezoid Inlays w/ White Side Dots
Gotoh Stepped, 13/32 x 11/32, Tuner Ream
Electronics:
MojoTone  '56 Quiet Coil P-90's
CTS, 500K, Audio Taper, Split Shaft Pots
.033uf Sprague Orange Drop Tone Caps
Switchcraft, Short Type, 3 Way, Selector Switch
Pure Tone Jack, GF Jack Plate
Gavitt 22 AWG Shielded Push Back Wire
Hardware:
Gotoh 510 Wrap Around Bridge, X-Chrome Finish
Gotoh 510, 21:1, Tuners, X-Chrome Finish, Tortoise Buttons
Planet Waves Elliptical Strap Buttons, Chrome
Gibson Top Hat Knobs, Black w/ Chrome Inserts
Standard Switch Tip, Black
"Modern" Les Paul Pickguard Bracket, Chrome
Extras:
Custom Headstock Decal, Buried Under Satin Lacquer
Custom Acrylic Pickguard, Tortoise on Cream, 45 degree Beveled Edge
Custom Engraved Titanium Neck Plate, w/ Black Frame
Custom Engraved "Amy" Truss Rod Cover
Custom "Twin Mountain" Label in Body Cavity
Stew Mac 0.5° Shim in the Neck Pocket
Fret Work By "Cagey"
Set-up By Owner
September
Guitar #11 Wreckless The Clown
Warmoth swamp ash body swirl dipped by me.
Fender American tremolo system.
Seymour Duncan Lil Screaming Demon (bridge), Duckbucker (middle), and Little 59er (neck) pickups.
CTS pots.
Orange Sprague capacitor.
Cloth push back wiring.
Fender custom shop gold anodized pickguard.
Warmoth roasted maple neck, wizard profile, Dunlop 6100 frets, and locking tuners.
October
Guitar #12 Dano
Purple Rain
Body:
Model: Chambered Stratocaster®
F-Holes: None
Scale: 25-1/2"
Wood: Flame Maple on Alder
Rout: Rear Rout
Pickup Rout: Strat® (Neck), Strat® (Middle), Strat® (Bridge)
Controls: V-T-T-5 (Strat®)
Bridge: Wilkinson Tremolo
Stud Install: Use inserts from bridge on order
Jack Rout: 3/4" (19mm) Side Jack Hole
Contours: Contoured Heel / Tummy Cut / Forearm Contour
Binding: Natural Masked Accent
Top Finish: Purple Dye
Back Finish: Transparent Purple
Neck:
Style: Stratocaster®
Neck Wood: Highly Flamed Roasted Maple
Fingerboard Wood: Roasted Maple
Nut Width: 1-11/16"
Back Shape: Standard thin
Fret Size: 6150
Scale: 25-1/2"
Fret #: 22
Inlays: Black Face Dots
Side Dots: Black Side Dots
Finish: No Finish
Wilkinson VS100 Tremolo
Seymour Duncan Hot Rails for Stratocaster Pickups
CTS 500k Potentiometers
0.022uF Russian P-I-O Tone Capacitor
November
Guitar #13 Hendrix
Killer top Koa Stratocaster
Custom finish deep amber color Vintage Tint
Warmoth High Grade Birdseye Maple Stratocaster replacement guitar neck with Abalone Face Dots , 1 3/4 Width , 59 Neck Profile .
Warmoth High Grade Flame Koa Top on Koa body Stratocaster ( Rear Rout SSH , No screw hole in 5 way switch )
Special order EMG shape Bareknuckle Strat pickups, Apache neck, Slow Hand Mid, Lace Sensor Dually Purple-Emerald Humbucker bridge .
DIY Custom Copper finish pickup cover and Knobs .
Gotoh Machine Heads, Gotoh Wilkinson Tremolo
Guitar #14 Dano
Grandson #2
Warmoth Neck
Construction: Modern Tiltback Construction
Neck Wood: Highly Figured Roasted Flame Maple
Fingerboard Wood: Pau Ferro
Nut Width: 1-5/8"
Fret Size: SS6150 (Stainless)
Scale: 25-1/2"
Fret #: 22
Inlays: Abalone Face Dots
Body
Telecaster Body
Flame Maple Top with Leopard Wood Stripes on Mahogany Body
Owner finished with StewMac Colortone Dye and Gloss Nitrocellulose Lacquer
Hardware:
Grover 505G locking tuners
Whole Lotta Humbucker Pickups
Hipshot Bridge
500k CTS Pots
.022uF Russian P-I-O tone cap
3-Way Blade
Pretty easy choice all things considered, seeing as it's the closest build to what I want to do. Good luck to everyone though, they're all stunning builds.
I voted. The thing that's so great about these contests is all the fantastic work you wouldn't otherwise get to see. They're all beautiful.
Hard to imagine there weren't winners the first time around--I know I voted for a couple of them.
OK, I'm in too. Like many here, I also voted for some of these guitars first time around. Good luck to all!
And for anyone interested in a closer look at "Amy", my CasinoCaster, here's a link to everything there is to know:
https://www.unofficialwarmoth.com/index.php?topic=30946.0
Good luck to all.
Here is a link to my tele build thread for those who may want to look further.
https://www.unofficialwarmoth.com/index.php?topic=23725.0
Well, this "runner up" contest is a testament to the quality of the instruments that won!  Lots of fine instruments here and anyone should be proud to have created them and that extra bonus of having them to play!
I am very proud to have three of mine in the mix.  The one that I am most proud of is the Flame Maple and Leopardwood Tele that I built for my grandson.  It is only my second try at applying dye and nitrocellulose lacquer on a guitar.  It took a huge learning curve for me to make the flame show up like it does.  The natural masked binding was also a first for me and I feel like it turned out better than I expected for my first try.
Here is a link to the build thread.  There are a few more pics that I added since I changed out the neck.
https://www.unofficialwarmoth.com/index.php?topic=30999.0
Best of luck to all!
All beautiful instruments indeed.  I always like to check out what’s up for voting each month.  It’s pretty cool to see the variety that’s posted here and in the gallery.  Good luck to all!
Hey guys, thanks for not forgetting about me.  I know I don't post much but I at least try to log on every month and see the builds and cast my vote. I wish I had more dough for some more Warmoth stuff so I could be more involved with this great forum but it can be elusive.  Here's a link to my first project guitar build featured in the runner-up list:
https://www.unofficialwarmoth.com/index.php?topic=30467.0
And the winner is...
Hendrix
Many congratulations to him and thanks to all the great entrants throughout the year!
