Sadie-f
Edit: Tl;dr per my biases
Fender lt25 C- & honorable mention @ dirty
OC 20rt B+ very usable dirty chan
THR 5a B extra points for tiny size
TheAmp 100 A
I'm curious what others like and why (obviously valve/SS is a main divider for a lot of guitarists, so beyond that).
I mostly play thru my SS Orange Crush 20 RT, it offers a decent sound at apartment volumes, good response across the range. When I re-started playing guitar at the outset of pandemic, I quickly realized I wanted to add an electric, and had that in hand by August of 2020. I went with the only cheap amp available from the same shop which was the Fender Lt25 (next step up in price was a Milkman head at $700 and then it was on to $1000+ tube combo amps).
The LT25 was a nice starting point, I setup a few flavors of clean channels and hardly ever used the various modeled distortion / effects. The one complaint I had was, as I improved my playing, it didn't seem to keep up, just a little muddy, I haven't used it at all since getting the Orange and it will soon go out on Craigslist.
Recently, I plugged both into a signal generator (so amps only, no speakers in the chain) and looked at harmonic distortion from both amps, I was a bit surprised at what I saw. at A - 440Hz, they were close to comparable, Orange had only one overtone peak at 880 (-40 dB) while the LT showed 3 peaks above -35 dB, so probably 4x higher THD. The surprise came at feeding the amps lower and higher frequencies. At 82 Hz, the LT25 power amp was clipping the top 20% of the waveform and at 1 kHz, there were -8 to 12 dB 2&4 kHz harmonics. The orange was still clean at the higher and lower notes. Also I *think* the Orange OEM speaker is also a little nicer sounding than the one Fender is using in the LT25, maybe I'll replicate my tests thru the speakers using a mic.
I also wanted something small enough to carry in a small backpack or large handbag and tried the Orange micro (9v battery/4" speaker). I was disappointed badly by that one and returned it, I couldn't get much louder than the bare strings of a strat without turning up preamp gain into distortion / crunch range. I'd really wanted to like it, however even using its headphone driver was disappointing. If I always played distorted, I'd have kept it tho, it's TINY and makes decent sound if you don't want a clean setting. I've replaced that with a Yamaha THR5A, a decent compromise between easy to carry around and good enough sound to enjoy using it.
I've plugged into Carr and Magnatone amps at the local shop and for sure they sound good, I just don't know as yet that they sound good enough for me to plop down 5-10x more $$ or to want something that much heavier. The Milkman is attractive, I've got a 15" Yamaha PA speaker it could drive quite nicely (not that I could ever turn that combo up in our tiny apartment).
[EDIT]
Awesome responses, of course I knew in the back of my mind we have FA-AXE-FX users, shoulda included that in the poll responses. Being a self-centered woman, I biased the options towards < $500 systems.
For now, I'm still committed to spending more on instruments than electronics, the reason is that I see more difference in sound between my factory Fender and my mahogany / rosewood build & pickup choices than I do between amps.
And while I'm definitely interested in informing my future plans, it's absolutely cool to hear the various approaches to amplification equally from those going directions that aren't practical for me!
TheAmp 100 A
[EDIT]
