VanHeGen
@BroccoliRob thx, that sounds alarming!try a sliver of business card between the neck screws closest to the neck pickup. since u did 12-16 radius... is it a plain Floyd Rose Original™? those have like a 10 radius out the box, same as a R2/3/4. if you remove the shims under the saddles it'll be a 12, or you can adjust them to make it flatter. ime (in my experience) going 16 or 18" at the bridge is best. if not, even if u have the bridge at the 'correct" height the arch of the strings will be freaked up. find a aftermarket 12" floyd style nut and adjust the shims to make the bridge 16 or flatter. right now with just a original Floyd and a 12-16 neck your geometry is just wrong. functional, but far from ideal
I planned the guitar for two years, asked all possible questions on this forum, other forums, from Warmoth, Schaller, etc. The (compatible) radius part was one of the things that I focused the most on, so I would have assumed that would have been correct. All my research and findings are documented here, btw https://unofficialwarmoth.com/threads/coffee-–-my-“superstrat-with-a-twist”-build-and-lessons-learned.34904/
My Floyd is a Lockmeister 6 that is 12” out of thebox and 16” when the shims under it are removed (they are). There are separate shims under the individual string saddles in the bridge, for the geometry - to make it about 18” at the bridge.. The locking nut is 12” (also Lockmeister). The neck is a 24.75 conversion neck, btw.
When it comes to the neck shims one can appraently buy them from like Stewmac, and based on this article things should be doable with them. Finding the right shim (combination) might apparently be difficult ??? https://hazeguitars.com/how-to-shim-a-bolt-on-neck
