WindsurfMaui said:
And I think the showcase "newest" feature doesn't actually seem to work so I can view the newest bodies and not have to spend website time looking at bodies and necks that I've already seen. Thanks
There is an issue with the the default sort order (for any category). Although "Newest" is selected, the items are not in order of newest to oldest. One must first sort by something else (i.e. price), then sort again by Newest. Note that once you've done this, the site will remember the latest sort preference and properly apply it to other categories. That said, if you close your browser, the preference is lost and you must repeat the process above. And yes, there is something artificially slow about the site's behavior. It should not take as long as it does to sort and display items. The slowness has been present since the new site launch.
If it helps, below are some links based on the search feature that list items in order of newest to oldest. These are based on naming conventions for different categories with numbers that may eventually change and thus stop working as intended. Incidentally, search results seem less affected by the slowdown than normal category browsing, possibly because they do not load the search refinement options.
Finished Strat Bodies:
https://warmoth.com/catalogsearch/result/?cat=0&q=ps-1
Unfinished Strat Bodies:
https://warmoth.com/catalogsearch/result/?cat=0&q=s-11
Finished Tele Bodies:
https://warmoth.com/catalogsearch/result/?cat=0&q=pt-8
Unfinished Tele Bodies:
https://warmoth.com/catalogsearch/result/?cat=0&q=t-7
Vintage Modern Strat Necks:
https://warmoth.com/catalogsearch/result/?cat=0&q=vms-
Modern Start Necks:
https://warmoth.com/catalogsearch/result/?cat=0&q=sn-
Vintage Modern Tele Necks:
https://warmoth.com/catalogsearch/result/?cat=0&q=vmt-
Modern Tele Necks (and Baritone necks, which are 'btn-'):
https://warmoth.com/catalogsearch/result/?cat=0&q=tn-
Certainly, additional searches could be created for other items
