New Warmoth Site Bug Megathread
Status
Not open for further replies.
TheElvis said:
Guess not a bug? Fuchsia Flake is not there anymore  :dontknow:
Yeah, Apricot Flake was the one I was missing. I kept waiting for someone to bring it up, but I guess they're just unannounced changes. I'm curious whether it's for good or just a current shortage issue.
ValeBliz said:
It’s me or they just made a 20$ price hike on all the body woods?  :-\
They look the same to me.  That said, I've noticed that for the Soloist, they are all $20 more than for Strats and Teles.  But I think it's been that way...
See attachments:
Gone for good AFAIK. Discontinued by the manufacturer.
See attachments:
Soloist is $20 more because it's rear-rout, which means a rear rout cover and screws are included. A rear-rout Strat costs $20 more than a top rout for the same reason.
Oh ok, never noticed and I own a soloist body. On the other hand, I ended up ordering a custom Musiclander body yesterday and it wasn’t 20$ more.
Hmm... There are other models that are rear-route-only and don't have $20 added to the price of the core wood.  There are also some that have $30 added to the price of the core wood.  I doubt the cost of the cover and screws has much to do with it.  More likely it has to do with adjustments needed for non-standard requests or less common models.
Hybrid Tele body - Bug.
Under Hardtail options there are no options for recessed TOM with Angled, Arched or staggered strings. This is available on Strat, Hybrid Strat and Tele bodies so would expect it to also be available on the Hybrid Tele.
Noticed you can’t choose unique choice tops for thinline teles, is it normal? Looks like a bug.
BUGs...
From https://warmoth.com/guitar-bridge-routs
A number of the green buttons "Shop xxx type of Bridge" particularly for Post Mount type bridges do not work correctly.
https://warmoth.com/index.php/catalogsearch/result/?f=+hardware+guitar+bridges+fixed+bridges+tune+o+matic+bridges&q=hardware+guitar+bridges+bridges+tune+o+matic+bridges
gives no useful result.
Should probably use this as a link instead. https://warmoth.com/hardware/guitar-bridges/fixed-bridges/post-mount-bridges
Came across 2 new problems on the website last night. 1) when looking in the Strat replacement neck showcase I tried to sort for canary shaft wood necks. It said next to canary that there were 17 in ()s. Then I noticed that it said there were 17 for every wood type listed. And of course there were no Canary necks in the showcase. Problem 2) when I did a custom neck build and then went to the bottom to save it to my wish list the heart icon was missing so I couldn't save it. Is there some reason why the save icon is no longer there? Thanks.
Can't choose a Carved Top Telecaster® Replacement Body without a lam top.
I just want a curvy front on a bog standard ash body. Oh, hang on, is that because the carved top isn't carved but a curvy bit stuck onto a slightly thinner bodied straight sided main piece?
Also can't remove the 'Contoured Heel' from the carved top Telecaster, you can untick the box, but it comes straight back again.
The contoured heel is standard on most carved top bodies. I suspect this is a feature rather than a bug, as the builder probably needs to specify contoured heel, meaning if you uncheck it puts it back again as described.
Perhaps an email or call to the mothership may confirm whether or not the contoured heel can be omitted by special request.
If you want a Carved Top Tele body, no lam top, no binding, you can call or email. It's an off-menu option.
I was looking at the american standard flatmount bridge and it has the diagram with string spacing at 10.5mm (.413") but in the string spacing in the description of the actual bridge it lists it as 2-3/16
https://warmoth.com/hardware/guitar-bridges/fixed-bridges/flat-mount-bridges/fender-standard-flat-mount
One of these is wrong.
Also, could you tell me the distance from the center line of string holes to the center line line of the mounting holes.  I was wondering if the Gotoh fx510-x would fit.
I asked Gotoh and they pointed out warmoth's measurements wouldn't match up.  Those guys are on their game.  Any clarification much appreciated.
I thanked Gotoh-san for his assistance.
I think this is the wrong entry it should probably be 2 1/16" especially if an F Spaced or Trembucker is not needed.
If the guy from Gotoh says their bridge wont fit the Warmoth fender spacings I would go with that.
This'll be fixed in a few moments. The bridge itself is indeed 2-1/16"... well... more like a half mm in between 2-1/6" and 2-1/8", but let's just call it 2-1/6".  :icon_thumright:
Status
