New Velocity Build Under Way
To me, the best option with purple is gold...  It's pretty much the only time I'd go with gold hardware.
F-hole is no mojo. Just house for bugs.
Bwahahahaha!  I love it!
On a tangential note, other than natural masked binding (which isn't really binding, at all), has anyone ever gotten away with painting binding a different color?  Say you found a body that is otherwise perfect in the Screamin' Deals section, but it has pearloid binding and you wanted black.  With proper masking, sanding, painting, and clear coating, is this ever done?  Can't say I've ever read about it (but that doesn't mean anything).
I've never seen/heard of it being done, but I imagine it's possible. Except in rare cases on high-end acoustics, most binding is made of ABS plastic, and it takes a finish readily. It has to, or you couldn't clearcoat. The tough part would be masking and then levelling after the fact to get a uniform surface. Past that, I guess I'd be concerned about damage later on. If you put something dark over something light, the fact that you'd have a relatively sharp edge would mean that chipping it would be pretty easy, and the damage would be quite obvious.
How about rebinding an unfinished body?  There are a couple in the showcase that have kept my wallet happy by having the wrong binding.
I've got a crazy idea...may change everything.  If they can do it, Seafoam Green will be involved... Mwaha..mwahaha...mwahahahahaaahahahaa!
Seafoam Green is being involved.  If this turns out hideously, then no one will ever see or hear of it again!
Consider me subscribed. Interested to see where this one winds up Frank. If it turns out half as nice as Doc's DD did, you'll be fine.
