I have always set the relief on a strat by putting a capo on the first fret & either depressing the string on the fret where the neck joins the body or on the last fret, depending on the guitar, & use a gauge to measure from the string to the fret at the 8th fret, which is how fender tells you to do it. I know it depends on the radius of the neck & Fender gives examples of the gap settings
Neck Radius Relief
7.25" - .012" (0.3 mm)
9.5" to 12" - .010" (0.25 mm)
15" to 17" - .008" (0.2 mm)
Just curious if there is a recommended starting point for a 10-16" radius neck? I have ended up using a gap of about .007" with the string depressed at the last fret. Ended up with this just by experimenting.
Neck Radius Relief
