GoDrex
mayfly said:.
Spent tonight tweaking. Feel is where I want it
so what is it that determined the "feel" on this thing? I'm just curious what you had to adjust to get it where you wanted it.
mayfly said:.
GoDrex said:that's really sweet that it's that configurable - sounds like it could drive a non-tweaker crazy. :laughing7:
You are on the walk nowmayfly said:There was no one thing, but a pile of different things. mostly it was adding some gain before the front of the amp, tweaking the sag control, the master, the power amp input freq, the LF and HF resonances, selecting the right mic, and adding a EQ 'block' at the end of it all. It's a lot of fiddling, but the more you fiddle, the more you figure out what works for what.
Spent the evening (after the festivities were over) A/B ing it with the tonelab. Now it kills the tonelab in all patches. The tonelab sounds thin in comparison.
Ultimate test will be with the entire band - scheduled for next week.
Lol... Cool. Oh and thanks for using the ultra as your signature picture....I wasn't thinking about it enough.... :-\ :icon_smile:mayfly said:BTW - you can change the button / patch assignment to be whatever you want.
I'm just too lazy to change it.
Gregg said:Lol... Cool. Oh and thanks for using the ultra as your signature picture....I wasn't thinking about it enough.... :-\ :icon_smile:mayfly said:BTW - you can change the button / patch assignment to be whatever you want.
TBurst Std said:You are on the walk nowmayfly said:There was no one thing, but a pile of different things. mostly it was adding some gain before the front of the amp, tweaking the sag control, the master, the power amp input freq, the LF and HF resonances, selecting the right mic, and adding a EQ 'block' at the end of it all. It's a lot of fiddling, but the more you fiddle, the more you figure out what works for what.
As you are going FRFR, try a blocking PEQ: blocks on Freq 1 and 5.
This thing through FRFR is possible of so much more than an amp/cab from a freq standpoint, a blocking PEQ tends to remove those freq that amp/cabs do tend to bring out.
Actually I haven;t used mine in a little over a week. Been on an acoustic kick, partially fueled by a new acoustic last Tues.
mayfly said:Well, there is one thing that I find annoying:
patch numbers start at zero, which is fine. However, the first button on the pedalboard is labeled '1'. So, in a stock non-modified setup, you press button '1' to get patch '0'.
and here's the best part: the current patch number is displayed on the pedalboard and when you press button '1', the patch displayed is, ......
ready for this?.....,
ZERO!![]()
I tend to run them right after the cab block.mayfly said:TBurst Std said:You are on the walk nowmayfly said:There was no one thing, but a pile of different things. mostly it was adding some gain before the front of the amp, tweaking the sag control, the master, the power amp input freq, the LF and HF resonances, selecting the right mic, and adding a EQ 'block' at the end of it all. It's a lot of fiddling, but the more you fiddle, the more you figure out what works for what.
Should I throw these blocks as the last thing in the chain?
TBurst Std said:mayfly said:Well, there is one thing that I find annoying:
ZERO!![]()
You can modify this. This is an offset available in both the AXE as well as the MFC.
I have my AXE and LFP set so the 1st patch is labled 1 instead of 0.
Isn;t MIDI fun![]()
