I did this separate....
From the 1930's till bebop, the most common "gateway" out of diatonic play was the diminished scale and it's attendant set of chords - m7b5, Dom7b9 etc. This also brought in "tritone substitution" - look it up."Chord Chemistry" and "Advanced Chord Progressions" by Ted Greene go there, as do any/all books on jazz construction. The bebop guys added "superimposed triads" - play the three notes of a G chord, add the three notes of an Ab chord - what happens? Do you like it? Play the G notes again, add a Bbm triad - what happens? Do you like it? Explore ALL POSSIBLE COMBINATIONS - it's no wonder nobody wanted to be Coltrane's roommate on the road. :toothy12:
ALSO: scales are boring to listen too, if it's played seven up, seven down... scale fragments are interesting. So:
1-2-3-4, 2-3-4-5, 3-4-5-6
8-7-6-5, 7-6-5-4 etc.
And in threes: 1-2-3, 2-3-4 3-4-5 etc. up and down:
6-7-8, 5-6-7, 4-5-6 etc.
4-3-2-1, 6-5-4-3, 5-4-3-2, 7-6-5-4, 9-8-7-6 etc.
Chord arpeggios, touched on above, are critically important. In threes and fours:
1-3-5, 2-4-6, 3-5-7, 4-6-8 up and down backwards and forwards. 1-3-5-7, 2-4-6-8, 3-5-7-9 etc
There's always four permutations. The fragment can rise or fall, and the movement of the fragments can be up or down. It never hurts to repeat one once in a while.
If you listen to good music, you will hear the fragments above in hundreds of places. Just working through one scale using all the possible combinations can take weeks. And then there's the five note fragments and the eight note ones, and.... chord arpeggios using altered and five-and-six note chords, and...
I will post more around 2014, when you've learned all this. :toothy10:
