Now that I have a FR, I was able to sit it in the guitar and I quickly determined I was going to have to recess the FR. Sitting flat against the body, there is a slight rise to the top of the saddles. This gets considerably worse once you line the FR up with the studs. This is especially true with this tremelo because of the plate holding the studs together. Not sure why that was done because, for me at least, it's forcing me to recess a little more then I would otherwise have to. I thought about getting other studs, but since I have to route the thing out anyway, going a millimeter or two deeper doesn't seem like an issue.
I went to StewMac's website to look at their templates and noticed in their instructions that they specify that the studs should be 25 inches from the nut for a FR. Mine are 25 1/8. So, I am going to (somehow) trim about an 1/8 inch off the heel of the neck. If you look in the pic with the neck sitting upside down in the pocket, you can see that the heel of the neck is rounded while the pocket is flat. Obviously, this neck was not built for this body, so taking a little off also gives me a chance to flatten out the end of the heel. A whole separate issue is the fact that both the body and neck are shaped for Ibanez's All Access Neck Joint except that they don't line up, so I will be reshaping that part of the neck at some later point. Have I mentioned that this stuff is not Warmoth quality? :icon_smile:
Rather then wait a week for an order from StewMac, I opted to make my own template to recess the FR. So the last pic is the FR sitting in the template. I will probably do a test tonight to see how it works out.
