+1 amen and halleluja!Death by Uberschall said:Carvin
dudesweet157 said:Welcome to the forum!
To give you a serious answer, we need a bit more info about your situation. First, are we talking one single amp for both bass and guitar or an amp for each instrument? Your post wasn't entirely clear. Second, what styles of music do you play, and when you play live, are you going to have PA reinforcement or carry the room with your stage volume?
Personally, I would totally abandon the idea of an all tube bass combo amp for live music. I don't even know if they make one for less than $600, and if they do, it's going to be stupid heavy and in all likelihood won't be able to hold it together in the low end at gig volumes (unless you're going for the distorted bass tone).
For guitar, you can get a lot of amp for $600 if you buy used. I can't really give you good suggestion without know what you play. Do you need clean volume or are you going to be playing mostly distorted?
dudesweet157 said:First, are we talking one single amp for both bass and guitar or an amp for each instrument? Your post wasn't entirely clear. Second, what styles of music do you play, and when you play live, are you going to have PA reinforcement or carry the room with your stage volume?
The Central Scrutinizer said:I am thinking about giving this one a try...
it is small, cheap and it has a effect loop... while most small tube amps never have that..
http://www.musiciansfriend.com/guitars/vht-special-6-ultra-6w-1x12-hand-wired-tube-guitar-combo-amp/h73575000000000
The Central Scrutinizer said:I may interrupt the service/ceremony to give a detailed review.. :tard:
Luke by Vox said:For bass, is Gallien-Krueger any good at all? I'm not up on my bass gear, as I always play through the PA..
