Guess what I'm making
Another piece of the puzzle has arrived.  Soon to be installed along with the tuners.  Gonna line up the neck dontchaknow.
AprioriMark said:
Where were you playing in Vegas?  I'm there a fair bit and would have loved to have seen it.
-Mark
Hi Mark,
I was playing a little hole in the wall place called the Cellar Lounge.  I think there were 10 people in the audience  :headbang:
Doesn't matter. Now you can say you've played Vegas. You're up there with Frank Sinatra, Elvis, Liberace, Tom Jones, Conway Twitty, et al.
I'd be careful invoking Sinatra; I once saw a King Crimson concert at the Chicago Theatre, and Adrian mentioned he signed his name in the rafters right next to Sinatra's; three songs later his voice was completely gone... stolen by Old Blue Eyes?  :sad:
Or, you know, it could've just been laryngitis or something.
Lot's of fun last night.  First I installed the bridge studs:
I used a block of soft wood and a very hard hammer.  With the posts installed in the studs (not the tone pros posts - but some others that I had that came with the bridge):
Both installed.  Including grounding wire (sorry Greg):
Those Tone pro thingys really work!
Next I put in the beer cans, er I mean tuners:
I did all this to ensure that the neck would be lined up correctly.  In hindsight I probably didn't need to:
Kinda looks like a guitar!
Time to glue.  Titebond?  A dab will do ya.  Carefully...too much could cause gaps as glue dries.
Gentlemen,
Last night was spent puttering around - mostly because I'm avoiding the big glue event!
I decided I would drill all the hardware holes that I needed and test mount hardware:
and I made a little clamping caul for the top of the fretboard.
I'm out of things to do!  Time to glue it I guess...
That's a cool jig.  Another tip is make sure the neck is seated at the butt end too.  Some clamps, depending on what you use, can exert a small amount of horizontal pressure.  Make sure the butt of the neck is completely seated after you clamp.
What I have done is scribe a small line on the back of the neck where it meets the body.  This is done during a dry fit.  When I glue, I check the line for any separation.  If there is a gap, the neck has slid.
Just is case I am not giving an accurate account, think of hanging a guitar by the neck and having the body slide down...this the type of gap I am mentioning.
Also be sure to have a damp rag handy to wipe off excess glue.  If it sets, it is really hard to remove.
Gentlemen,
The main event:
I used titebond III and used a brush to get it evenly on both surfaces.  When I was happy with the application, I clamped it down.  Didn't get a lot of squeezeout (some but not a lot), which is different from my usual glue experience, but perhaps that's because I took a refined and measured approach this time rather than just gloping the stuff down.
I'll give it the grab test in 24 hours.
Just a link to the topic your on:
http://www.youtube.com/watch?v=VndZX0QlErI&feature=player_embedded#!
Hey!  It's a guitar!
Neck joint is fairly tight - I can't slide a piece of paper in there anymore:
Titebond III has 52% solids, which apparently is good for gap filling.  Seems to have worked on the (small) gap that the neck joint used to have.
Now I just have to get the thing to Tonar!
That's gonna be nice, Nice, NICE!
How'd you talk Tonar into doing a Mahogany body again? Last time he did one, he said he was done with them <grin>
I think that was because of the TV White for Max, was it not? I'm sure Trevor doesn't have something that torturous in mind for Greg. Then again, I wouldn't mind a TV White LP Jr....
Yeah, I think you're right. I don't think it was the TV white that bugged him, though. It was filling that pesky Mahogany. I've done it myself, and can attest to its low level of fun.
