Why doesn’t it move around? Is the humbucker cavity too tight?The pickguard is from 920D and there's no way to move it around to even get it close.
I don't know. I got the universal route so I could maybe later swap the guard out if I didn't like it.Why doesn’t it move around? Is the humbucker cavity to tight?
There are no lose wires yet. I'm just trying to do a mock up. Just got the body and neck today.What's catching the side of the route beneath the pickguard, preventing you from moving it into position? Maybe it's a wire or something else that you can redirect? Hard to believe Warmoth would get the universal route wrong. That's done on the CNC.
The bottom tone pot cannot move side to side at all. So there's no way to move the bottom of the pickguard over at all. The neck side of the pickguard moves maybe a centimeter or less side to side. It pivots at the bottom tone pot.Can you take a pic of the guard mounted as straight as you can get it from the front with the whole body in frame? Is the neck pocket and horn lined up when the bridge is askew?
I think this spot is the reason why my old pickguard from my other strat won't fit right, but I'm not sure if it's why the 920D won't line up. I'm stumped
Definitely worth doing a test fit that way.I'm going to take a wild guess. I think the placement of the lower tone pot on the 920D pickguard may not be same as a Warmoth pickguard, or even a Fender pickguard. If the control route on the warmoth body is smaller than the MIM body, then it may cause this fitment issue with the 920D pickguard. It would be possible to check by unscrewing the tone pot and doing a test fit.
