Cactus Jack
I just picked up a neck with this tuner bore. After reading several threads I can’t seem to identify any tuners that fit this bore perfectly. Vintage doesn’t appear to work and modern tuners are 10mm while the actual bore is closer to 10.3mm, which apparently leads to a loose/sloppy fit.
Can anyone recommend a set of tuners that fit perfectly? I do not want any play and I’m fine with vintage, modern, locking, non-locking. I just want a nice sung fit for rock solid tuning. I might be a little ( a lot OCD), but I really want zero play.
Thanks for the help and recommendations.
