Fusion Latino Concept
fusion6
I have something in mind...
Mahogany Velocity body/Quilted maple top with aquamarine dye
Mahogany Hombre neck 44mm with rosewood fretboard.
Set up for nylon strings.
Passive under saddle piezo transducer pickup with volume control only.
That looks pretty nifty.  I might personally prefer some means of onboard EQ, at least for a performing axe, but I am a big fan of the simplicity.
Take lot's of pictures on how you do this because it's been a dream of mine to make something like this, but I always get thwarted by how to do the bridge in a non-strat guitar.
Very nice idea! Although I would say that you may want to consider some type of pre-amp, depending on exactly which pickup you go with as it's hard to get good volume without one with most of the under-saddle types.  :headbang:
Sduck or scartozi did a nylon string about 10 years ago. I know scartozi did that cool bridge for one.
I hope you don't take this the wrong way, but I can't understand why people think its acceptable to have necks with angled nut-slots such as Hombre necks and almost all Gibson guitars.  For one thing, it makes the tuning stability worse.  Would your design still be aesthetically ok if you change to a Vortex neck?  If no, then that's a fine reason to choose it.
Hi everyone.
Thanks for interacting with my post.
I have attached an updated image of the concept which in fact is an illustration of what I had in mind before proceeding with the first image.
The new image addresses forum member Johnny Hardtail's point of the more beneficial design of the Vortex neck compared to the Hombre which allows for more straight contact of the strings from the nut to the tuner shafts thus improving tuning stability and intonation.
Also, as can be seen, instead of a traditional classical guitar bridge, I'm opting for a tune o matic piezo style bridge which will make completion of the project vastily more easier since the prep work such as the angled string holes and TOM bridge holes will already be done by Warmoth during the order procsess, as well as intonating once complete.
I will however proceed with a passive system as I'm sure it will be absoloutly fine because as much as I would like to include a preamp, it is exceptionally hard to find a way around it without resorting to using a side mount system which would be too wide for the side, to ugly and Godin-ish on the front or top and would simply not conform to my personal preference which is to retain the 'beauty spot' look of a simple single volume control. I have built one like this before, albeit in a tele shape, as well as a tele jazz also with a passive system and it was loud enough. (For the record, I'm not a proffesional builder or luthier, just a hobbyist). If I need extra juice, I simply use a preamp pedal, even the likes of a Zoom multi effects pedal will suffice. Ben Woods who does the Nylocaster also uses passive electronics and it sounds brilliant.
As concept, a lot a details, small or big, could change but the updated image is the closest thing too what will transpier.
I will eventually make it in other finishes too and another eletric version albeit with Warhead neck, with a mini humbucker in the middle position for fusion/blues/jazz, which I will call the High Velocity Fusion Warhead, a deadly thermonuclear weapon for new-wave jazz  :icon_thumright:. Or I'll simply call it the Fusion Casino. Hint, it'll be finished in dark blue.
PS. Does anyone else have a nightmare of a time posting on this forum because of those verification questions? I succeed on like the 100dth attempt and on some browsers you can't at all.
More concept variations of the Velocity Fusion Latino
Further concepts, including the Fusion Folk and Fusion Jazz
I know the top doesn't really matter sonically, but I think it's be hard to beat a bound gloss clear mahogany body/spruce top for any sort of solid body "acoustic".
