*FINISHED!* Dave Murray 'Aces High' Signature Strat
Last rant on someone else's thread about this, but:
The thing that's so crazy about the part I'm looking for - the M6L mini is one of the most popular tuners ever. There are over 7 million of em out there. Yet when they produced an M6L locking mini for import, it's not replacement compatible. They do make one which is, the one I'm trying to get. But nobody in the entire US carries or is willing to order it.
And oh yeah, since I haven't said so: Wow that's a smokin hot guitar. I had my doubts when I saw the first drawings and stuff but this is way cooler than I thought it could be.
Allparts should (being the key word) be able to order anything Schaller offers. However, they will rape you on cost and it will take them months to actually get it. You will have to call them, and pester them about it and/or spam email them to get the ball rolling... good luck!
ORC
In addition, whatever your personal opinion about Patrick Sims is - the turtle gets some public lovin' on his frontpage!
www.simscustomshop.com
Update time!
Right. (Whew), time for the pickguard assembly, wiring, hole drilling ( :sad1: ), and lots of test fitting... Here we go!
First off, I ordered no less than three different pickguards all with different materials as I didn't know what I'd go with in the end.
As previously mentioned, I decided to go with the .90 black gloss/white/black pickguard. In the initial planning stages, I wanted
to do a full copper shield of the inner cavity. After doing a lot of research and consulting peoples' opinions I trust, I decided
against the full shield. But since I had a whole bunch of adhesive copper sheets laying around , I decided to lay down one continuous
sheet across the entirety of the inside of the pickguard. All of the edges were carefully cut and de-burred, leaving about an 1/16th
of an inch from all edges including the pickup and control cutouts (except for where the 3-way switch and pots were to be mounted).
I had these perfect little washers that I used for the pickup mounting springs just so the tension of the springs wouldn't mess with
the copper shielding or pickguard plastic over time. Not needed, but hey, I had them - and I think it makes for a cleaner looking setup.
I work in IT by trade, and I build custom PC's for people - so I had this really cool black cable sleeving kit. It's sort of a black plastic
weave that looks like steel braided brake or hydraulic lines and it easily stretches to accomodate various wires and cables. I used the
sleeving kit and shrink tubing to make all the pickup wires neat and tidy up until things started splitting off to be soldered to the switch and pots.
For the components used:
1x RS Guitarworks 280K SuperPot - volume
2x CTS 250K audio-taper pots - tone controls
1x AP Vitamin Q Oil & Paper cap (.022uf, 400V)
1x Oak Grigsby 3-way blade swtich
1x DiMarzio Super Distortion (DP100), Blk/Blk, F-Spaced (Bridge)
1x Fender Custom Shop 'Texas Special' RWRP single coil, with black cap. (Middle)
1x DiMarzio PAF 36th Anni. Edition (DP103), Blk/Blk, F-Spaced (Neck)
Some may note that these aren't really 'proper' values for components to pair with the pickups in this build. But, these same values are found in Dave Murray's
'Kossoff' stratocaster, which in turn are the values found in a normal three single-coil strat; 250k controls all around. Dave never changed them when he added
the humbuckers to the 'Kossoff', so thats what I'm going to use. The only liberty (or departure, if you will) I've taken is the use of an RS Guitarworks 280k
'Superpot' in lieu of a standard Fender 250k volume control pot and I'm using the AP Vitamin Q cap instead of... whatever Fender used for a cap 'back in the day', 1963 in the case of the Kossoff.
I've never wired a guitar before (or ever messed with the innards of any guitar for that matter), so I'm pretty happy with the result. Very clean IMHO, but I
had a lot of help from my friend Josh who's my soldering expert. Thanks Joooosh!
All done and ready to go:
The pickguard was taken downstairs and plugged into the amp and tested before installation into the body - and lo! everything worked perfectly!
Special thanks to Mr. Martian (aka Roy) who helped me with the wiring schematic, thanks Roy! Dave's control setup is a tad different from the regular
strat setup. Tone #1 controls the neck, and since Dave almost never uses the middle single coil, Tone #2 controls the middle and bridge pickups.
Here's a shot of the body with all of the holes (shudder) I had to make for the pickguard and input jack. Not a single power-tool (not counting the
soldering iron) was used on the guitar. I have a hand-held modeling or jewelers drill that I used for all the holes. Everything came out perfectly, much to my relief!
And here we have the completed pickguard and jack, installed and secured...
Another angle...
Here's a (bad) shot of the spring claw, and you can barely see the bridge ground (soldered on the reverse side of the claw for cleanliness), snaking
off to the control cavity on the left:
This is a shot of the body illustrating the tremolo rout. I had picked up a sheet of thin, self-adhesive neoprene padding that I intended to use to protect
to tremolo recess rout. When it came down to it, I couldn't decide if I should show the beautiful paint or protect it. Test fitting the trem, I found that
there was a good half-inch of painted area in the rout the trem didn't cover. I didn't want to cover that up, yet didn't want the trem leaf spring (according
to Schallers engineering schematic, called a 'Bronce spring') to mar the finish. So I compromised and cut a half-inch strip and placed that directly
under the leaf (or Bronce) spring and where it would contact the body if there was no string tension on the trem. That way, the paint is protected directly
under the spring, yet the entire route isn't covered allowing one to see the paint the trem doesn't cover. Works for me!
Here's a shot of my wicked Ruthenium trem and something I decided to try out: a 37mm bell-brass sustain block with stainless steel mounting screws.
I have Floyd's on all of my other (two) guitars and after reading the rave reviews on tone and sustain I figured I'd give it a shot. I should have taken some
pics of the OEM block for comparison as it looks really wimpy next to the brass one. Not in the pic's (I think) are also a set of 'Raw Vintage' tremolo
springs. Also designed to increase sustain and recommended by some fellow forumites, I thought those plus the sustain block would make for a nice one-two punch...
Previous to this stage of the build (I had eight months to kill), I bought and installed these nifty Floyd Rose saddle shims. The Schaller Floyd Rose
has saddle radius of 12 inches. Using the saddle shims, I correctly adjusted the saddle heights to match an approximate 18" radius at the bridge
to properly compensate for the curvature of my Warmoth compound radiused fretboard:
Test fitting the trem... here you can see the neoprene strip due to off-angle of the picture, but looking down from the top/front its completely hidden...
Another wierd angle, lol...but its my favorite of the bunch as it shows off the true colors very well.
And here's a final shot of the trem and pickguard before bed!
Allright, thats it for now - its 2:30 in the AM and work calls in the morning.
As always, comments and questions are welcome!
ORCRiST
What? No ruthenium pickup ring for the single coil? What kind of cheap, half-assed Rube Goldberg setup is this, anyway? <grin>
Just kidding. Looks great. Won't be long now and you're be doing dive-bomb noises like Mr. Hendrix used to do for fun and profit.
I like the white outline of the pickguard. Seems to make it look even more "mechanical".
The only odd thing is the appearance of the knobs, since you have the volume slightly shifted. I know that's personal preference... my brain is just having a hard time seeing that since I'm so used to the knobs being in straight line. But you're not gonna be looking at it, you're gonna be rocking it!  :party07:
In it's stock position, it would interfere with the bridge pickup mounting ring.
Great thinking with the cable sleeving, very slick look. I find myself liking this guitar, even though it's a str*t. It's a weird feeling :icon_biggrin:
sorry, but I can't help but wonder what it would look like with a dark blue guard (to match the blue bullseye) . . .with yellow sandwiched in there.
the attention to detail on this build has been top notch, it is going to be a show piece for sure, to bad it will have to be played
Jusatele said:
the attention to detail on this build has been top notch, it is going to be a show piece for sure, to bad I'm so glad it will have to be played
FTFY
Thanks again all. I consider myself very fortunate that things are going so smoothly (knock on wood). As I've
always heard, its better to be lucky than good. :)
Believe me man, I know exactly how you feel. I frequent the Fender Stratocaster forums and have friends over there too.
They kept asking me to start my own build thread there, and I held off until I actually recieved the body. Its basically a verbatim
copy of this thread (although not as detailed and with different responses) - but, at the very beginning of that thread I describe
how and why I hate stratocasters (on the official Fender forums, mind you) - needless to say I share your thoughts.
LOL. To tell ya the truth, I actually ordered three humbucker rings from Schaller, with the intention of
indeed chopping one apart and fabricating a Ruthenium pickup ring for the single coil. Luckily my obsession
to detail saved me, as Dave's guitar only has rings on the humbuckers, I was spared.  :laughing7:
Maybe you'll have to find out for yourself with the 'Sopwith' build, eh B3???  :)
ORC
or a Mirrored one as a little hint to that blue Steve Harris bass1 ;)
I actually like it the way it is now!
Its together - and it ROCKS!!!  :headbang1:
Still have some tweaking and intonation to do, but it already plays like a f-ing dream! I can't say enough about Warmoth or their awsome product.
The neck and neck pocket are a rock solid fit, all I had to do was clean out some lacquer that built up over the sides, that being said: Patrick did
a kick ass job getting rid of 99% of the overspray and sanding down the pocket as much as he dared. Bravo. Initial impressions (I cant decide more
to just stare at it or play it!) are the body is very resonant and it sustains like theres no tomorrow! I thought it might be on the heavy side but its
surprisingly light and very balanced (it might be the lightest guitar I have and thats saying something as my Jackson is very light). And before
someone asks, no I dont know how much it weighs, no scale for me.
Pics at night (its 2:00am here), so I tried some creative stuff until the morning and a proper cleaning.
Enjoy, more pics down the road!
Kitty peering at me from across the fretboard....
The neck in all its glory. :)
The decals came out really well! In this shot I was trying to capture the light reflecting off the surface to illustrate that the decals can't be seen or felt
in any way. I'm glad I took my time and waited to get it just right even though I wanted it just done weeks ago. Rock.
THANK YOU to everyone on this board, I could have never done this without your help! /BOW  :occasion14: :hello2: :headbang:
ORCRiST
