Does Warmoth do set necks?
Bananaguy191
Hello, I'm a noob to Warmoth and their practices. I'm wondering if Warmoth will custom make a set body and neck as I'm planning on building a guitar with that specific design. So I'm just wondering does Warmoth do that type of stuff.
[Also, here is the type of guitar I want to build for reference.]
First question I've got to ask you is: Have you perused the Warmoth website? They won't custom make that for you, you'll have to do the work. What I'd recommend is that you have them do a blank for you, with pups, switches and pots in the places you want, a bridge rout that looks good to you, and you cut the outline to your liking. Otherwise you're going to have to go to your local luthier. I suppose you could use that high tech device called a telephone and call them Monday morning, but I'm pretty sure that would be the answer.
Warmoth do not do set necks and are a custom parts supplier based on bolt on neck designs.
There is a lot on the menu - see the website but not for custom set necks.
