Custom Chambered Pupleheart/Figured Maple Build
I was able to utilize the treaded screw with a tap.  the Wax did not not work.  I think the combo so super soft brass and super hard wood was the issue.
Mm....solid brass goodness.  Have matching bridge too.
I has a change of plans.  I cannot use a tom-stop on this.  Too much neck angle needed and poor planning on my part.  I will need a strat style bridge.  Still going to use some brass!!!
Neck is ordered....what else...purple heart and maple.  I will let the shape be a surprise.
"No plan survives first contact with the enemy" as von Moltke used to say... I am so very intrigued to see this progress, it's going to be very cool and unique!
well said.
I am doing final prep tonight.  Unfortunately it is going to be 95+ degrees over the next few days.  I will have to wait to spray.
Are using rattle cans or a spray gun? If you have a gun and are mixing the finish yourself, just add some retarder to the mix on very hot and/or humid days. It'll not only prevent blush/frosting, you'll get less orange peel out of the deal as well.
spray gun.  I have never used retarder.  How do you mix?
It's easy, and it doesn't take much. Depending on how hot/humid it is, you'll use between a 1% to 5% mixture.
Lacquer dries by evaporation, so the hotter or drier it is in your paint area, the faster it dries. Get a high-temp low humidity day, and the stuff will practically dry coming out of the gun. Since it skins over so fast, air and moisture gets trapped under the surface and that's what causes the dreaded "blush".
Retarder slows down (retards) the evaporation speed of the vehicle/solvent/thinner (acetone) by raising its boiling point, so the lacquer has a chance to get on the target and stay wet long enough for any microscopic air/moisture bubbles caused by atomization and/or condensation at the gun to escape.
A shot glass is close enough for rock 'n' roll when mixing, as it's not hyper-critical. 1 shot roughly equals 1% in a gallon. I usually mix by in a quart jar, so I'll do half lacquer, half acetone, and a shot of retarder. Gives me a roughly 50% lacquer retarded 4%, which works out pretty good with my rig and my painting style in moderate humidity and upper 80s to mid 90s temps. But, I'm sure everybody does it slightly differently because you have different spray guns, different pressures, different painting styles due to pattern selection, etc.
DangerousR6 said:
Interesting stop tail, never seen a curved one as such...
Yep.  GFS XP line.  Seems like a really nice piece.  I will have to save it for another build.
I sprayed the final nitro coats.  Here is a pick of the side plates.    Great flame on this purple heart.  Now the hardest part, waiting for it to cure.
This is the first body I have not put any kind of dye, paint, or flake on.  The wood was so amazing it speaks for itself.
They look fine but if you want them to look less obvious, change them to black.
The guitar is coming along nicely. :icon_thumright:
I agree. Doesn't look excessive, but black ones wouldn't advertise their presence as much if it bothers you.
My dad was the original "too many fasteners" guy. If 5 were good, 15 were better, and 50 were just about right. "That oughta hold the little bugger!!" he'd say. He built a set of swinging doors one time that weighed so much by the time he was done that they wouldn't swing. Used gravity hinges, and the weight just made them gall  :laughing7:
I like seeing them.  I think it looks fine.  Just unnecessary.    They are too long too.  I could have used ones 1/2 the size.    I should finish wiring tomorrow.  Just need the neck now
Very cool, I like the look of the screws, it gives it that mechanical look or industrial look...I see something else there too... :laughing7:
Yep.  I had to take it off, just temporarily.  Not centered.  I may have miss aligned something.  I want to wait till the neck and bridge are set.
I just got the notification from big brown, my maple and Purple Heart neck is on the way.  Warhead 24.75 scale.
Looking good, dude! Can't wait to see it completed. I really like the amount of screws. Looks super cool over that purpleheart.
Having just ordered a purpleheart / ebony neck, and beginning my wait time :) I eagerly await pictures of your purpleheart / maple neck!
TZ
