Cagey
Mythical Status
I was afraid of that.
It depends on how the thing operates. If the pattern is something that changes over time, or the color is something that involves modulating two or three primary colors (R,G,B) to derive, then you'd have to shield everything and it may still not be 100% effective since the LEDs will necessarily need to be exposed. The problem shows up because in order to get that kind of operation, the controller needs to be clocked, and that's effectively AC (more accurately, switching noise), which is what your pickups are hearing.
Normally, that sort of thing wouldn't be a concern because I'm sure the controller isn't radiating much at all, but the proximity of the controller to your pickups, which are specifically designed to be sensitive to such signals, is too close.
