rockskate4x
Hey, guys... what bridge choices have problems with compound radius necks? I like a TOM, but I'm worried about buzzing on the frets or bad intonation with a compound radius... What do you think?
I didn't and it's fine. However, I have a gotoh Floyd and it's a bit different.GoDrex said:You won't have intonation problems. I did notice the inner strings seemed a little higher the higher up the neck they go. That can be adjusted if needed.
Floyd Rose bridge saddles need to be shimmed - since their default radius is 10" I believe.
If you ever need to figure out the shims for a Floyd: http://spreadsheets.google.com/ccc?key=pwDGkNlS5ESXuEj7hDA_VMQGoDrex said:You won't have intonation problems. I did notice the inner strings seemed a little higher the higher up the neck they go. That can be adjusted if needed.
