ACWraith
Please check my work. This is the first wiring diagram I've attempted. :binkybaby:
I started with the HH Series Phase Split 1V1T diagram offered in this PDF on StewMac. It claims to be humbucking in all positions. I flipped the neck pickup to use outer coils. Then I used the 3x3-05 2PU 4Pot PDF offered by Free-Way themselves to help switch to 2V2T and adjusted it for '50s wiring. The 4 wire colors were changed to match the Seymour Duncan pickups I plan on getting.
I have a computer science degree and am well aware of novices who grab code from different sources and merge it together with no clue of what they're really doing. Sadly, I now find myself doing roughly the same with electronics. I have some knowledge, but the rest is taking my sources at their word without full understanding. I didn't change the wiring on the switch itself at all. Multi-position 4-pole switches seem simple enough and I appear fine with series, parallel, and out of phase connections. However, there's things like why Neck North Start is on 4A just to connect to nothing that I don't quite grok. Meanwhile, the original diagram didn't show the pickup poles so I'm not sure if I screwed up the opposing coils when I allegedly flipped the neck pickup. :dontknow:
