Cheap Thrills Tele
looks good.  Bolt the bridge on an use a drexel to take out the needed material.  That wood is likely Palwana and soft.
That's probably one of the weirdest tele bodies I've ever seen. The pickguard is nice!
Got the routing template!  As you can see, the original route is, well, just a bit non-standard.  :headbang:
index.php
Allright!  It's a nice day outside, so let's get ready to route!
Body is ready.  I countersunk the holes in the template before bolting it down.  The tape is just in case I accidentally tilt the router or something.  More in a bit
index.php
Thumbnail looks like a green Tele with a turtoise bridge plate, maybe for your next build :icon_tongue: ?
Might look good with a different green. Or monkey vomit gold.
Doesn't everyone route outside in the back yard?
index.php
end result looks pretty clean
index.php
Now that's better!
index.php
Unfortunately found the next problem:  The pickup wire hole is so high in the body that the pickups won't go into the hole!  I think a specialty drill bit is in my future...
index.php
That's one of the most beautiful Tele pickup cavity routes I've ever seen. You missed your calling. You should've been a Tele pickup cavityrouter instead of an electronics design engineer/professional musician. It's not too late, you know. You could still become a guitar tech and make minimum wage part-time. Think of the stories you could tell! Plus, chicks dig cavity routers.
What he said.... :toothy12:
<blush> stop it!
Looking mighty fine. Too bad about the hole being placed too high. What kind of clowns design those bodies at GFS? :doh:
All right!  Let's deal with those pickup wire holes.  In this body, the neck pickup was drilled into the bridge pickup cavity.  I didn't like that.  Also, all holes were too high.  I didn't like that either.
A quick trip to home depot produced this:
index.php
Looks somewhat intimidating doesn't it!
index.php
