Actually, I built the amp accouple years ago, but never got around to building custom speaker cabinets for it. So that is my winter project. I inherited some 10" x 12' oak planks from my grandpa after he died, and decided to use those for sentimental value. They had them as shelves when they owned the gifttree in hastings. The boards were a little weather worn and warped, so step one was to rip them all down to roughly 1.5" wide pieces and reglue them all together. Then they were run thru a planner and cut to width. The next step, was to cut the sides to length and using a dado blade and a home made jig, cut 3/4" finger joints in the ends. Saturday night I spent some time cleaning up the joints and dry fitting the sides together. Glued the first box up last night. Going to cut the finger joints to length on the other tonight and glue that one up.
Once those are glued and squared up, I will round all the edges with a router and move on to the front panels. The panels for the front are going to be stagered oak, with a hole cut in the middle for the speaker. They will be recessed slightly in the boxes, with a strip of cherry trim around the front. This is the general idea, poorly executed in photoshop
The amp itself will sit inside a similar box, but will have an open front and back so you can see the tubes glowing. I ordered leather handles, rubber feet, jacks, and jack plates that should be here today. Next will be the speakers. Planning on Celestion Blues.
The amp is a 1.5W tube amp. I built this one using the fireflyPCB, but I am already scoping out schematics to do another higher wattage amp using point to point wiring
I've got a new aluminum case for it, as the other got buggered while drilling....
