Corey P.
Definitely assemble it to the point you're comfortable doing on your own. Even if you aren't comfortable installing the electronics, play it acoustically and live with it for a good while at first and learn its quirks. Most any player is capable of performing a very acceptable setup, and there are some great guides online, plus as said you may find it's perfect for you as-is, but if you encounter any dead spots or oddities a proper fret leveling/dressing & setup will likely cure all those ills, and especially with stainless steel frets where they wear so much less (if at all), you'll really only need to make minor truss adjustments seasonally. This forum has the "Find A Guitar Tech" forum, and I'm sure there's at least one reasonable tech in NY, or one worth his/her high prices.
I can say with absolute certainty it will be well worth your while to get your guitar professionally set up since this'll be a guitar that'll be with you for the long haul. Most likely one of many, given most of our tracks records.
