Cagey
Mythical Status
My understanding is that the Floyd locking nuts are a 10" radius, but the bridge itself isn't dedicated. You put shims under the saddles to achieve the radius you want at that end. Most properly designed bridges have saddle height adjustment screws, but either way it's a setup issue. If you have a compound radius neck, then it flattens out as it moves toward the bridge, so the radius there will be much larger than it is at the nut. Picture a cone with a few degrees taken out as a slice for a fretboard surface. That's probably why your middle strings seem (or are) high. Have someone explain how to shim that bridge, or take it to a shop and throw $20 at it to have it done. It'll make you happier because you'll stop tripping over strings.
