+1 on neilium's reply; from CB's FAQ:
8. - How does the bias effect tone?
As the bias is set lower the amplifier will operate closer to Class-B. The tone will be a little "thinner" or less full since the amplifier will not be hitting it's output tubes saturation point quite as easily. If the amplifier is biased very low, higher volumes will encounter crossover distortion. Properly biased in a lower range, the overall clean headroom of the amplifier will be greater.
As the bias is adjusted higher, toward Class-A operation, the tone will be "thicker", "fatter" or more full. The overall headroom of the amp will be less, since the signal level at the grid, added to the bias voltage will be closer to the tubes saturation point. The amplifier will distort easier (musical distortion, not that nasty crossover distortion stuff).
9. - If I set the bias too high or too low, will it hurt the amplifier?
If you set it too low, then no harm can be done. If the bias is set too high, then there is the possibility that the output tubes will not be able to dissipate the extra heat, the plates will start to glow. The tubes will do a major meltdown. There is a possibility of power transformer and or output transformer failure if the failing tubes short.
The default Blackheart BH5H bias is NOT set too high for the Groove Tubes ST-EL84-S Silver series EL84, I've been running mine for a while now with no ill effects to tube/transformers/etc.
The Groove Tubes ST-EL84-S Silver series EL84 tube takes the same default voltage as the stock no-name Chinese EL84, but does not break up as bad at the max volume levels of pentode or triode mode of the amp; it's "cleaner", less distorted than the stock tube at volume, which is the sound I prefer....
