Deep Purple in Rock
stratamania said:Deep Purple in Rock said:stratamania said:Deep Purple in Rock said:So what if you didn't take the 50/50 side dot?
Would the side dot be placed on the fretboard or below the fretboard instead of on the seam between the board and neck shaft?
The 50/50 side dot places it lower than the alternative which is the centre of the fingerboard which is higher of course.
I suppose one wild option would be no side dots and drill for them and fit them yourself - though this is not always an option depending on where one sources a neck from. Or just go for a slightly shallower scallop.
So I should go 50/50 on a maple neck maple fretboard to come as close to the FCS malmsteen signature as I can.
Of the options discussed that would be the closest. Interestingly the early Malmsteen sigs had much shallower scallops than in more recent years.
You are like a living encyclopedia when it comes to Strats.
Thanks a lot for your help.
