kboman said:Holy crap!
http://www.youtube.com/watch?v=7rzFA_UiFWo
Holy wow. Crazy instrument, but way more impressive is the playing.
kboman said:Updown said:This is the way you play a wide neck ... (Great song too)reluctant-builder said:How in hell does one play on a fretboard that wide?
http://www.youtube.com/watch?v=RCXjEIQANes
If I ever get a wide neck, thats what i'll buy. :icon_biggrin:
Greg Howard is ridiculously good, but I'm not sure I like his tone. Trey Gunn has more mids, and that's what I prefer:
http://www.youtube.com/watch?v=2YAnun4CgUc
Exactly, no point after 4 strings, just geta piano... :icon_thumright:Alfang said:They got a name for guitars like that with so many strings, I think their called pianos
line6man said:Why are there two straplocks a half inch apart at the bottom? :icon_scratch:
DMRACO said:line6man said:Why are there two straplocks a half inch apart at the bottom? :icon_scratch:
it is so massive it needs two straps
Wyliee said:DMRACO said:line6man said:Why are there two straplocks a half inch apart at the bottom? :icon_scratch:
I think you are looking at the output jacks. Yup, it's got two output jacks.
Needs a Turbo Deluxe Floyd said:Just for Line6man, I'll call them input jacks.
Needs a Turbo Deluxe Floyd said:I PUT the cable IN the jack. Input jack.
Needs a Turbo Deluxe Floyd said:Now we're getting into the difference between a cord and a cable, something I care even less about.
DangerousR6 said:It's both, for just that solitary moment, you are "inputting" the cable into the jack, then and only then does it become an "output"... :icon_biggrin:
You missed the sarcasm... :doh:line6man said:DangerousR6 said:It's both, for just that solitary moment, you are "inputting" the cable into the jack, then and only then does it become an "output"... :icon_biggrin:
It's not both. Input versus output designation is based on the transmission of power through the receptacle.
In the case of a guitar's jack, the signal flows out of the jack. The exception being if you want to run a direct current through the cable, either on the tip, with the signal, or as a separate supply on the ring terminal of a "balanced" cable with TRS connectors and jacks, to power some active component on the guitar. In that case, it is both an output for the signal, and an input for DC power, except when the flow of current reaches 0A for the output signal, then it indeed functions solely as an input jack for as long as the signal's current stays at zero.
But most people don't care either way. Gary just knows which semantic arguments set me off. :blob7:
