Any other wiring sickos out there?
Goldietops
First post on UW, so I thought I’d share my own personal, most ambitious (insane?) wiring project to date.
Humbuckers: Sheptone Tribute neck (A5), Sheptone Heartbreaker bridge.
Controls: Series/parallel on either pickup, passive treble-bass tone circuit for each pickup (PTB), switchable no-load blend pot, standard 3-way switch and master volume w/ treble bleed cap.
Signal Path*: hots from humbucker up to the respective outer series/parallel switches, from those switches down to the respective PTB tone controls, from the tone controls to the 3-way switch, from the 3-way switch (a) to the volume pot, and also (b) neck/bridge wiring from the 3-way back up to the blend switch, and from that switch to the adjacent blend control.
*Note: It’s been years since I hooked this up, but I’m pretty sure this is the correct schematic. Unfortunately, I didn’t write it down anywhere, but everything works as intended. More knowledgeable folks can correct me on anything I might have gotten wrong..
The output options on this guitar are unlike anything I’ve come across. Standard series output? Easy. Bridge in series with neck in parallel? Done. Bridge in parallel with some treble rolled off before blending in some series neck with some neck bass rolled off? I gotchu. For someone who has absolutely no use for something like this, it’s incredibly useful. Just thought I’d share this monstrosity.
Lordy. And no odd combos that cause everything to go to ground?
How many combos do you actually use?
None. I somehow made this mess work as it should. The wires look like spaghetti under the hood, but there’s no hum and no grounding issues. I did have to solder some shorter leads to longer wires for the top-to-bottom-to-top-to-bottom runs.
I really don’t play nearly as much as I would like, and these four walls are my only audience. Mostly use the bridge and dial in a little bit of parallel neck sounds with some bass rolled of the neck. I find that pretty pleasing for dirty licks that gives a little bit more body to the sound. I want to get around to recording some original tracks in the future, so I’ll be tweaking things much more at that point. I’m sure someone could put something like this to much better use than me, but I’ll get there at some point…
I think I can beat that...
A pair of Semour Duncan P Rails pickups.
Each pickup is attached to a 6 way rotary switch that gives:-
1) coils in series
2) coils in parrallel
3) 'P90' coil
4) 'single' coil
5) coils in series but out of phase
6) coils in parallel but out of phase
positions 5 and 6 are almost useless - until - wait for it!
There is a Telecaster 4 way switch giving bridge, neck, pickups in parallel and pickups in series.
And there is a phase switch.
positions 5 and 6 become quite interesting when out of phase with the other pickup.
of the 134 or whatever possibilities 32 of them are we could call useful in everyday playing.
1) coils in series
3) 'P90' coil
4) 'single' coil
Wow Dave T, that truly is sick isn't it? I don't Think it's possible to top a p rail for sickness but here's what's floating around in my head
HsH five way switch
Auto split
Master split volume
An S1 switch as a tone control and a dual phase flip/inner outer coil toggle (or two phase switches for humbuckers)
A blender pot as another phase push pull
What do you get
Well you get the Strat 5 you get inner coils outer coils north/South coils all three coils
Two humbuckers that's a Gibb son
Turn the neck pickup down a touch to take the bite off Justin Ostrander/Clapton style
And Peter Green. Peter ****ing green.
(and sort of brian may)
Then to make a true monster utterly depraved you could perform the Waylon McPherson dual load tone pot mod on the S1 switch and have 50s wiring/ modern wiring no load tone in the same axe with different cap values if you so desire.
All without a freeway blade switch.
Suck S**t **nts have a nice one.
Not sure if that made sense my wiring diagram is essentialy this
Modified with a neck bridge 7 way blender
Two HB polarity switches, and a dual load tone pot. OR if you use an S1 for both HB polarities another polarity switch in series with half of the S1,
And a dual load master tone pot
The reason you have 50s and modern wiring options in a guitar would be the different response different amps can have
With the posted schematic polarity flipping switches interact with coil splits to change the selected coil.
Thanks! Glad I didn’t show you what it looks like under the control plate. You’d call the cops.
I'm mostly impressed at how that fits in a tele rout. Two PTB circuits AND a treble bleed? That's a 5 capacitors and 3 resistors crammed in there with two concentric pots. My guess is those caps aren't orange drops!
I love a good wiring challenge. I've drawn up quite a few diagrams over the years for folks on other forums, even once corrected an error to a Seymour Duncan diagram many years ago, but when it comes to my guitars, I don't like having to throw a lot of switches. What I do like is finding a way to add just one extra switch to find something a little less common.
  • I have a strat that, in addition to the traditional 5 strat position, with a single push/pull I unlock bridge + neck (parallel), bridge + middle (series), and neck + middle (series). That strat also uses a PTB circuit.
  • I have a pair of two humbucker guitars that use a single push/pull to perform a coil swap, where the bridge stud coil is placed in series with the neck screw coil, and vice versa. This is more impactful when one of the pickups is rotated so that the two series positions are inside/outside, and when using a humbucker with unequal coils. Super useful tones.
Some pretty cool wirings I see in here.
I like trying different options but never got that far.
Lately I tried a simple mod that I think makes a more traditional one a little easier to keep in your mind in the middle of playing.
In a 3 pickup arrangement (SSS, HSS, HSH etc), manufacturers mostly use a switch to turn either the neck or the bridge pickup always on, in order to get the all-three or bridge+neck options.
E.g. with the switch turning neck always on (sending its output to the switch output). That gives you the following switching:
1. Bridge+neck
2. All-three
3. Middle+neck
4. Middle+neck
5. Neck only
I thought instead of sending the neck or bridge pickup output to the switch output, it would be a little easier to just connect the bridge and the neck outputs together.
Like that, you get:
1. Bridge+neck
2. All three
3. Middle only
4. All three
5. Bridge+neck
So it's a little more symmetric and easier to remember.
Middle position you get the middle pickup. Moving outwards you get all three at positions 2 and 4 and further out you get Bridge+neck at positions 1 and 5.
So, it's like transitioning from middle to bridge+neck moving to the outer positions. Middle, then turn bridge+neck on, then turn middle off.
1. Bridge+neck
2. All-three
3. Middle+neck
4. Middle+neck
5. Neck only
Like that, you get:
1. Bridge+neck
2. All three
3. Middle only
4. All three
5. Bridge+neck
I’ve played quite a bit with the “Seven Sound” Strat wiring as well. I’ve found I do not like duplicates in my switching options, so I usually go the other direction with it. On a Strat, when the switch is engaged, it adds the neck pickup only to position 1 and 2, so Bridge becomes Bridge + Neck, and Bridge + Middle becomes All 3. Other positions are unchanged, and the Neck and Neck + Middle remain intact. On a three pickup Tele, I go the other way so as to keep Bridge-only available, and the switch adds the Bridge to positions 4 and 5 to get All 3 and Neck + Bridge.
I’m glad I found this thread, definitely makes me feel like some of my crazy wiring ideas are not so crazy after all 😅 A couple of other notables for me are a Tele with WRHBs with Arlo and Eldred Esquire mods wired in to the 2 and 4 positions of a 5-way, and a Jazzmaster where the upper circuit is both pickups in series with dedicated volume and tone and an S1 switch gives in/out of phase for both circuits.
Edit: Found pictures of the wiring from the afore mentioned Jazzmaster. PTSD!
I am just a simple caveman your world of push pull pots and mini switches frightens and confuses me!
