SkuttleFunk said:both of those require a 15/32" drill size - OK for a 5-string, but too big for a guitar or 4-string IMO
SkuttleFunk said:how much clearance do you have between the mounting hole centerline and the edge of the neck?
all the best,
rR
SkuttleFunk said:I just re-read the Warmoth warranty page, and I don't catch where installing inserts voids the warranty. maybe someone from Warmoth could point to the text that is being referred to so we can know the technical side of this
all the best,
R
rahimiiii said:SkuttleFunk said:I just re-read the Warmoth warranty page, and I don't catch where installing inserts voids the warranty. maybe someone from Warmoth could point to the text that is being referred to so we can know the technical side of this
all the best,
R
Anytime you modify something beyond its design you will most likely void the warranty. Installing threaded insert isn't part of the normal expected things you'd do to a Warmoth neck but applying a finish is. Same thing if you pull out the fret and replace it...
Wyliee said:Tough question. Let's say something goes wrong, warranty terms are repair or replace at manufacturer's descretion. (This is a common phrase in warranties, BTW. )
.hmmm .. much stuff written and deleted trying to write up a cognizant answer... ... really tough question as there are so many possible scenarios ...
Best I can offer is the inserts, just like any post sale finish work, fret work, decals, etc... would not be repaired/replaced under warranty. If the modifications caused whatever the problem is, I could see it voiding the warranty.
Very few considering the number of bodies and necks that ship from Warmoth everyday.how many warranty claims does Warmoth deal with?
