JCizzle
Luke said:They do look cool..
I should make some that do nothing, just for the look.
You can get some that do nothing right on that site. :laughing7:
Jumble Jumble said:What you don't seem to get is that this is exactly the same for someone who does these things every day on a Mac who then tries it on Windows. What you are trying to do is use OSX as if it was Windows, getting it to do all the same things. It's the way of working that's different - OSX isn't just a different interface for doing everything exactly as you would in Windows. That's what took me some time to realise. Don't try and turn it into Windows; try and use it how it's designed to work. The number one tool for window management in OSX is Exposé (now called Mission Control ffs), which doesn't really have an equivalent in Windows.but then i scratch my head on how to do something i do every day on any other operating system
(Alt+tab has an exact equivalent on OSX - Cmd+Tab. It works in exactly the same way.)
You're arguing that OSX is objectively less easy to use than Windows and you don't seem to realise how much your unfamiliarity with it is clouding the issue.
Having said all that, I use both a lot and I do prefer Windows' window management paradigm. I think the W7 taskbar is brilliant. All I'm trying to say is, all those people who love it aren't wrong, they're different.
I think arguing about how easy something is to use the first time you use it (or saying something is better because "my grandma can use it") is pretty pointless. It's much easier to get a tune out of a piano than a guitar the first time you use it, but that doesn't make pianos better. Ease of first use and ease of continued use aren't necessarily connected.
The things I miss about OSX when I go back to Windows are: AirDrop and Spaces, which just don't have an equivalent in Windows. And there's some nice under the hood stuff like the OS-level AutoSave so that any app can have reliable auto-save. But then, Windows 7 has amazing developer support, is faster (yes it is - even running on a Mac) and, to me, feels more streamlined. It also has wayyyy more little freeware downloadable apps.
South-east. West Norwood.JCizzle said:What part of London, just out of curiousity?
AprioriMark said:I knew that Mac vs PC brings out the stupidity in people, but dang. I laughed heartily.
-Mark
Jumble Jumble said:South-east. West Norwood.JCizzle said:What part of London, just out of curiousity?
line6man said:In AC circuits, electrons actually do travel along the outer circumference of a circular conductor, and not the core. Google the skin effect.This is the physics the cable companies use to market all that fancy multiconductor cable nonsense, but most people know that it's actually not significant in the real world.
=CB= said:line6man said:In AC circuits, electrons actually do travel along the outer circumference of a circular conductor, and not the core. Google the skin effect.This is the physics the cable companies use to market all that fancy multiconductor cable nonsense, but most people know that it's actually not significant in the real world.
At audio frequencies, the effect is below nil... one little factoid that they fail to mention.
At audio frequencies, the effect is below nil... one little factoid that they fail to mention. Another is that they use stranded cabling which throws all the calculations out the window. You can get stranded cabling that has zero - ZERO - skin effect. Its called Litz wire. You may notice noise changes from grabbing a noisy cable with your fist, and squeezing tight. Thats not what's going on here... that... is from capacitive coupling to your body.
I'd say, you'd have better improvement with tone controls numbered to 12 or 15, rather than 10.
Dan0 said:=CB= said:line6man said:In AC circuits, electrons actually do travel along the outer circumference of a circular conductor, and not the core. Google the skin effect.This is the physics the cable companies use to market all that fancy multiconductor cable nonsense, but most people know that it's actually not significant in the real world.
these audiophiles are trending towards individually insulated single strands, they may run several in parallel. the hobbyist audiophiles are big fans of cat-5, the solid core stuff specifically. they use several runs in parallel in higher power situations. the guys that do a lot of low power stuff like pure silver magnet wire if they can afford it. they have some rationale based on skin effect for the solid core but i don't remember what it was. i have used cat-5 like this mostly because i have big spools of it and i don't have lamp cord. does it help? i couldn't tell ya.... but i doubt it.
Dan0 said:with analog video, reflections, capacitance and coupling are a concern and will cause artifacts and a loss in clarity so there are video cables and audio cables,
=CB= said:Dan0 said:with analog video, reflections, capacitance and coupling are a concern and will cause artifacts and a loss in clarity so there are video cables and audio cables,
Individually shielded parallel runs of wire, in a cable, is exactly what Litz wire is. They also weave, or braid, or twist the wire... according to application. Litz wire has very very little skin effect (but in audio... no biggie). Litz wire is use for inter-stage wiring, sometimes, in amplifiers.... not really in guitar amps though. Remember, guitar amps are capable of fantastic frequency reproduction, limited by their own filtration internally, and moreso by the frequencies guitar amp speakers can reproduce - mainly 50hz-7500hz and thats it.
I'm not sure how cat-5 cable will work... depends on how they implement it. Its four twisted pairs. Depending on which wires they use - and how the signal is put through the remaining wires.... I'm sure some smarty figured it out, but its about like wiping a baby's bottom with ostrich feathers.....
