ThisIsHuhWow404
Sorry, but my knowledge of how electronics in a guitar works doesn’t go much further than "solder this wire here, solder that wire there" and "if the ohms reader beeps when you touch these two pieces of copper tape at the same time that means you did it right."
The Dyna-MIX Alter Switch comes on the Ibanez AZ models. It’s a micro switch that changes how the 5 way blade functions, essentially giving you two different "modes." I’ll attach a diagram from Ibanez’s website that shows how one of the AZ models works.
Would it be possible to do this yourself?
Here’s the guitar that I have conceptualized in my mind I’d be interested in trying this on. As of right now it’s just an idea in my mind and I haven’t acquired any material to make it a reality yet, and doing so is a ways in the future, but I’m interested in any feedback from the fine folk here.
It’s a Telecaster with a 3-way micro switch that changes how the 3-way pickup selector switch works.
Mode One on the alter switch would be "Normal" with the 3 settings on the pickup selector being:
Neck pickup
Bridge and Neck pickups
Bridge pickup
With the tone knob and volume knob functioning "normally" in all three positions.
Mode Two on the alter switch would be a "Early 50s Broadcaser/Nocaster mode" where the pickup selector is:
Neck with dark circuit
Neck with the tone knob functioning normally
Bridge with the neck pickup controlled by the tone knob acting as a "blend knob"
Mode 3 on the alter switch would be "Esquire Mode" where the pickup selector is:
Bridge with dark circuit
Bridge with volume and tone
Bridge bypassing the volume and tone and just being wide open
I’d also like to maybe have an option for series/parallel switching, probably by a push-pull pot. If I’m feeling really innovative I’d possibly even have a middle Strat pickup for a Nashville Tele Setup, activated by another push pull.
I’m sure a setup like this would require a lot more than just a makeshift Ibanez Dyna-Mix alter switch, and I’m going to need to do a lot more research into things like no load tone pots, capacitors, and other things.
Is this guitar too imaginative to be feasible? I’m sure it would be easier if it was a Tele with much bigger routes and more to work with, like a Tele with LP controls, or something like the Hybrid Tele or Hybrid Strat that Warmoth offers, but I kind of want it to have that normal "Tele" aesthetic with Butterscotch blonde, black pick guard, and blade switch/one tone/one volume control plate.
Neck pickup
Bridge pickup
