So this here is my first build, and the one thing I can say is that it certainly is more work than I thought it'll be
I think the main lesson is- if you want it to be fast- don't look for new ideas on this forum as you go along But than again, if you want the absolute best you can have- do just that.
So here's a little story before the pics come:
All I really wanted in the begining was a jaguar with jazzmaster pickups. Now, being that Warmoth don't offer that, or a pickguard to fit, I've decided I'll go with the Jazzmaster and...improvise.
So, I wanted that jaguar plates look, and after some web search (google "jazzmaster jaguar comparison" or something like that) found schematics overlayed unto another so it seemed the plates will fit.
In the meantime I've spent all the time I could reading into guitar building, hardware, woods, pickups and what not. Here, and on the web, I found more than I could really comprehend, Hence, it took me a couple of monthes to finally decide what exactly am I going for.
The specs:
A warmoth jazzmaster Black Korina core and Indian Rosewood top. Chosen both for looks and for sound (;
And a Pro Construction Bloodwood neck with Goncalo Alves fingerboard, compound radius, black mother of pearl dots inlay and a graphtech black TUSQ XL nut.
These are to be fitted with Antiquity II Jazzmaster pups, a Warmoth modified Mustang bridge (yeah, I heard of the Mastery and decided it wasn't for me. Not for now anyhow) and Gotoh tuners (that have yet to arrive) with a height adjustment and locking mechanism.
Needless to say I was real excited when the parts arrived(=
By that time I have learned of the option to sand my raw neck (which, addmitingly, I got simply because that's how warmoth supllies the bloodwood necks, and I figured it has a good reason for it), and when everything got here I put in some records and got to work all the way to 2000 grit.
Before:
After:
Notich that the headstick was kept at 400 grit (so it still apears matte) as I wanted some reference for the feel.
The only downside for the neck sanding was that the grain became much more appearant. This might be some fault on my side or perhaps simply the wood's charecteristics, but I have no way of telling since this is the first time I'm doing such a thing.
(The camera's flash really enhances its contrast. It isn't as apearant as is, but still, you can see it)
But the feel is great, so I'm happy anyways :glasses9:
Anyhow, the pickguard modification has been the real headache. Upon checking the alignment I realized that the plate, although fitting on the pickguard, doesn't fit on the cavity! meaning- it had nothing to attache to or the where the pots shuuld go there's wood.
I tried all kinds of methods to figure out a way to fix this.
(I did the shielding before that. It came in handy with light reflection, but it got back at me later because I might still need to do some modifications on the body)
Eye, Ze problems iz quite appearant! Ze potz dontz fitz!
I'll save you the boring measurements I then took to see how still I can fit the bastard. It took a dremel, some files and much fine work and "rechecking" to see how it all goes. So far I believe it will turn out well(=
For those with the proper tools, perhaps altering the cavity would be better. I just didn't want to risk the body, and chose to risk the pickguard instead (;
the plan for now is-
1) Get threaded inserts and install them.
2) Get the tuners and install them.
3) fix the plate to the pickguard via some sort of glue (needed because of the modification).
4) Everything else
5) Rock.
Cheers!
P.S - anyone knows of problems I might stumble into when installing the inserts in a pro neck?
The specs:
Before:
After:
4) Everything else
5) Rock.
Cheers!
