TBurst Std
Correct as I recall.
Open top cover yes, no cover probably not unless it has a conductive metal baseplate.Have you seen the wiring diagram for a 3 Way Freeway Switch? I am attaching a pdf of it.
If I purchase a neck pickup which is uncovered or open top cover do I then not need the third wire for the Freeway switch? It seems like I wouldn't need it. I know Fralin offers open top cover neck pickups, which I really like. Not sure who else offers this.
Not very capable as of yet, but working on it. I just upgraded from a solder pencil to a Weller Soldering Station and will practice a bit before building the actual control plate with the Freeway switch.By the way if you’re capable of soldering at all, adding a third wire to a pickup is easy.
True on the last. I actually bought the Freeway switch to rewire my Warmoth HH Thinline, but haven't gotten around to that yet. Perhaps I should either stick with a 3 way switch, or buy a 4 way switch?Open top cover yes, no cover probably not unless it has a conductive metal baseplate.
Any metal on the pickup, ungrounded, is functionally an antenna. To fix that, we send that noise to ground with the ground wire, so you have to give the cover an additional path to ground if you intend to use series wiring.
Freeways are a darling of this forum in particular, but I think you’re veering off “classic Tele tones” a bit![]()
Use lots of heat, clean and solder the tip between connections, use leaded solder as needed. The Freeway contacts solder like a dream compared the back of the pot. Of course, pre-tin everything and only solder once you have a strong mechanical connection. A set of helping hands goes a long way to that last point.Not very capable as of yet, but working on it. I just upgraded from a solder pencil to a Weller Soldering Station and will practice a bit before building the actual control plate with the Freeway switch.
You are right. For this one maybe I go with a standard 3 way switch and keep it simple.Use lots of heat, clean and solder the tip between connections, use leaded solder as needed. The Freeway contacts solder like a dream compared the back of the pot. Of course, pre-tin everything and only solder once you have a strong mechanical connection. A set of helping hands goes a long way to that last point.
It’s your guitar but I think a classic Tele covers a lot of ground without any additional help!
NOW your on the right track!True on the last. I actually bought the Freeway switch to rewire my Warmoth HH Thinline, but haven't gotten around to that yet. Perhaps I should either stick with a 3 way switch, or buy a 4 way switch?
I have certainly heard of TV Jones pickups, but not familiar with them, and for sure I didn't know they made a Tele pickup set. I will look into them.Starwood Tele Guitar Pickups | TV Jones
Starwood Tele Pickups scream classic tele but with a dynamic and transparent top end. The right amount of punchy spank - everything you want from a tele & more!tvjones.com
You're welcome!![]()
I will check and see what I have. It is probably what you suggest, but ...Do yourself a favor and use 73/37 solder
This isn't strictly necessary.............Do yourself a favor and use 73/37 solder
For Cavalier pickups with vintage Tele sound, but a bit more "punch", sort of like Eddy Shaver in the Johnny Carson video where he is playing behind Dwight Yoakum on Little Sister, what do you think about the Nashville Lion Bridge Pickup, and either Lion King or Fat Lion King for the neck?I really like the Cavalier Pickups "Fat Lion" (slightly overwound A5 tele pickup) that I have in the bridge of my jazzcaster. Cavalier specializes in tele pickups and has a range of models, might have something to interest you. They're also pretty affordable. Highly recommended, if I were to build another telecaster I wouldn't hesitate to use their pickups. https://www.frettech.com/
As far as wiring mods, series/parallel switching is fun and can be done either with a four-way switch or push-pull.
Sorry to be a bit dumb here but for standard wiring would I just solder the third neck pickup wire (or put another way, the second ground wire) to a pot, and for the bridge pickup I wouldn't need to use the ground wired washer at all?The typical Tele pups have the metal cover / baseplate soldered directly to one side of the coil, so if you need to flip the leads you end up with an antennae that hums like crazy. The separate baseplate/cover leads are primarily for series wiring or out of phase switching, or, as Rob wrote, fixing polarity issues between different manufacturers.
You don’t need it for standard wiring and could just run a jumper from the baseplate to the ground wire.
