TBurst Std
Yes , the 60s Tele. It’s the lady on my arm at the gala and the slut under my sheets LOLSure, but have you truly made any one of them “ your bitch”?!!!!!!
Then follow my suggestion.Hard to say, I just love Tele's and always looking for variances in the "character" of the pickups. For example, I love my Fralin's, but just want to try pickups from someplace different to see if they do in fact vary in "character".
The Dimarzio's look interesting. I will research them more closely. That being said, I am thinking of two things now: (1) Contacting Cavalier, and (2) maybe sticking with Fralin and getting the Blues Special Neck paired with the High Output bridge. I would either have Fralin build me the control plate, or use my Freeway 3 way switch which allows for the 4 way switch functionality and more.Then follow my suggestion.
Larry D-learned under BillLawrence FYI. L-48.The Dimarzio's look interesting. I will research them more closely. That being said, I am thinking of two things now: (1) Contacting Cavalier, and (2) maybe sticking with Fralin and getting the Blues Special Neck paired with the High Output bridge. I would either have Fralin build me the control plate, or use my Freeway 3 way switch which allows for the 4 way switch functionality and more.
Have you tried the Wilde (Lawrence) Micro-coil Alnico? I have a set here but the body is in my box of shameLarry D-learned under BillLawrence FYI. L-48.
no sir haven't love the t280 neck thoughHave you tried the Wilde (Lawrence) Micro-coil Alnico? I have a set here but the body is in my box of shame
I know. Bill Lawrence pickups are great, but "vintage Tele" they are not.Larry D-learned under BillLawrence FYI. L-48.
Yes but they are naughty.I know. Bill Lawrence pickups are great, but "vintage Tele" they are not.
Just wondering why Cavalier has two websitew url's:I really like the Cavalier Pickups "Fat Lion" (slightly overwound A5 tele pickup) that I have in the bridge of my jazzcaster. Cavalier specializes in tele pickups and has a range of models, might have something to interest you. They're also pretty affordable. Highly recommended, if I were to build another telecaster I wouldn't hesitate to use their pickups. https://www.frettech.com/
As far as wiring mods, series/parallel switching is fun and can be done either with a four-way switch or push-pull.
Lol, I did not know that!
I will do that. I am interested. Still deciding but definitely want to see what he has to say.
2Just wondering about neck pickup wiring. Do the Custom Fender pickups like the 50/51 Blackguard have 2 or 3 wires in the neck pickup?
So to do 4 way wiring, with a 4 way switch, or the Freeway switch, would I then need to solder a 3rd wire (another ground wire) to the pickup and to the switch?
I do like Roy Buchanan! Not country, but definitely somewhat similar to the tone Eddy Shaver got on the Johnny Carson video clip where he plays Little Sister with Dwight Yoakum. Not country twang, but definitely a classic Tele sound.If you are into Roy Buchanan, you'll probably like Nick Silver's "Django" set. I also like Lollar '52 series T.
Have you seen the wiring diagram for a 3 Way Freeway Switch? I am attaching a pdf of it.You need to break the ground on the neck pup to its cover. Then splice a wire to it and run it to a common ground. Google it as you can have the series position other than position 1 (which is the norm)
