WindsurfMaui said:
Hello Stratmania:
So your saying it is where Warmoth drills the bridge on the 7/8 strat and not the fact that they shave off part of the heel pocket that determines whether it will take the 24 fret 25 1/2 inch scale neck. Good to know.
No, that's not really what he's saying. They don't shave off part of the neck pocket - that's the same size as a regular Strat. And... the 7/8 models do not take the 24 fret 25 1/2" scale neck, they take the 24 fret 24 3/4" scale necks that are specifically made for them.
It is, as Stratmania said, the bridge position relative to the neck pocket that determines which neck type you can use; Warmoth's bodies that are stated to be for 25 1/2" scale* can be used with 25 1/2" necks with 21 frets ('vintage' Fender spec), 22 frets (modern style with a small fretboard overhang) and 24 frets (large fretboard overhang). They can also be used with Warmoth's conversion necks - 24 3/4" scale with 22 frets and 28 5/8" baritone with 24. Mustangs, Jaguars and the 7/8 models have a shorter bridge to neck pocket measurement and - although the neck pocket is the same as the others - will only intonate correctly if used with 24" scale Mustang/Jaguar 22 fret necks (no overhang), or 7/8 series 24 3/4" scale 24 fret necks (small overhang).
Personally I think you're on the wrong track thinking about modifying a Soloist to look more like a Strat. If you try to make the horns less pointy, you'll end up with stubby, wide-apart horns - might be a good idea if you want it to look like an Epiphone Coronet.
Does this help?:
From what you say, it seems to me that the obvious choice is a 7/8 Strat. They're only a little smaller than a regular Strat but are the same basic shape, lighter (and are available chambered too, unlike the Soloist) and have excellent upper fret access.
What's not to like?
*Let's not confuse things by worrying about Telecaster neck pockets
