BlueTalon
I can't directly address that question, but I can offer you a couple things to think about. The first is the quality of pickup, and you're doing well by going with Nordstrand. If they're telling you that the Big Split is a good close substitute for a split P pickup, I would feel confident in using it.Mathieugr said:I’m also wondering whether the middle Big Split would be a good enough P impersonator that a separate pickup wouldn’t be needed. It’s the closest thing to a split-coil P according to Nordstrand, and the location is only a bit south of the P regular location...
The other thing is the positioning. I am probably in a distinct minority when I say I believe the precise positioning of pickups really doesn't matter that much. As long as you're close, you're good. (As you get closer to the bridge, it matters more, but where a P pickup is typically located, you have a bit of wiggle room.) There might be enough of a difference to hear a slight difference in an A-B comparison, but you probably wouldn't know which was which if you were blindfolded when you heard it.
