Strat Avenger
Can Tru-Oil be painted over? Would the paint adhere, or would it react badly?
Yeah...uhm......already experienced that situation, which is why I am trying to explore other options.What kind and brand of paint?
You generally want to stay in the same eco-system for finishes, the manufacturers work hard to make sure the products in the same line work well together. You start mixing products and you could get adhesion issues, cracked, flaking, etc.
Thanks for the info!Crystalac sells dewaxed shellac (either their own tub or the cans of Zinsser) as the sealer coat for going between their filler and their polyurethane topcoats, so I think the Zinsser idea is the best option to experiment with. Shellac will stick to most finishes and most finishes stick to it.
