I'm at work right now, and I just confirmed it. The meter beeps for a sec, then stops. As long as the cap holds the charge it won't beep again the next time you do it. If the capacitor behaves this way, you know it's good and not opened or shorted. I am not sure how everything is working for you other than a little noise, or a lot, but try this: With your continuity meter check your selector switch, and make sure the common output is in fact wired to the output, and the selector terminals are hooked into the pickups. The guitar may work haphazard and noisy like when I accidently did it wrong. You can verify this by leaving one lead on the common terminal, then moving the other lead to other terminals as you are moving the switch. If the continuity to the output lead that you have gets disrupted every time you move the switch, meaning you have to move both leads to find the continuity, then there is one problem identified. Der :tard:, I just read back to what you had written before: If the values in ohms that you are getting are 1 to 8 ohms or even 40 ohms, your grounding is in deep crap. It doesn't sound like the bridge is very conductive, but don't worry. When you are measuring between points don't worry too much about long runs that will have resistance anyway, like from the bridge to the pickup mounting screws. I would try the black lead on the control plate or whatever is most readily grounded to it, then touch the other lead on the extremities like the bridge, then the output jack, and any other point considered ground within the control cavity. If you can't see anything much less than 1 ohm, other than the bridge, you may need some copper ground wire to the bridge, jack, and other connections within the control cavity. The bridge could be chrome plated copper, and you might have to get to the copper to make a good connection. A six inch piece of copper won't even register as an ohms reading on my meter, so try to widdle those numbers down. My methods for grounding are a little anal, but they have treated me to very quiet guitars. I hope you fix it, and keep giving us updates, the more heads, the better.
