Some Tracks are with an ADA MP1, Some with an ADA MP2, both using a tube poweramp into 2 Custom ADA 4x12 cabs with OEM Celestion G12S50's,
Some clips are using a Pair of Digitech Valve FX preamps into an Tube poweramp, into 2 Custom ADA 4x12 cabs with OEM Celestion G12S50's,
Some clips are using a Johnson Millenium J250H amp head, with the 2 Custom ADA 4x12 cabs with OEM Celestion G12S50's
There were no active guitar pickups on any of these recordings, only the bass player.
We also had an Engl, Boogie .50 cal combo, ADA Microcab Cabinet Emulator, H&K Redbox,
In one of these rigs I had a Digitech IPS33B, DSP256XL, & that's about it.
Consoles used:
Neve console (not sure which model number) at room D in Expression Center for New Media, Emeryville, Ca.
Soundcraft
Mackie 32 channel.
ADATs
All guitar tracks used no additional compression from the console to mixdown. Only 2 tracks have effects added in addition to the guitar rig used, just a little Digital Delay (Roland DEP 5).
No additional eq was used, in fact the engineers in all of these tracks actually switched the eq "off", so what you're hearing is from rig to tape.
