drewfx
OK, finished this guy today. Saw the body in the Showcase and had uncontrollable GAS:
Warmoth Flamed Koa on Mahogany Body
Warmoth Flamed Teak neck (raw) with Ebony FB. It was a Showcase neck, so the blocks are stickers.
SD Lightnin' Rods AJJ-2 Active pickups
EMG BQC 3-band preamp
EMG active balance control
Push/pull volume - pulling up puts a .047 cap to ground on the neck PU (for a passive treble cut), and a .0047 cap in series with the bridge PU (for a passive bass cut), resulting in a "scooped" tone when both PU's are used (at the expense of some volume loss).
Hipshot D-Tuner
I didn't screw in the clear pickguard, as (so far) it stays in place very well, and there's no sense in drilling in case I change my mind about it...
Hipshot D-Tuner
