alterbridgefan
:blob7: My first post - worthy project!
Here we go! I want a good jag, so for lack of funds I need to do it myself.
First off, tell me all you can about this. Neck plate is stamped F and the serial number 182837. '65? Has most of the original shielding, but gone in the hummer cavity. Should I replace or repair?
It may look BAD, but what I have to work with is original body and plates, and shielding. It will need a lot, though. Tell me what you know!
Neck pocket leads me to believe that it was CAR.
The only routing/chilesing/chipping was for the hummer, and the only filling for the trem. If I go ahead with this, I'll be stripping the finish, routing the cavity, filling in all(?) of the holes, fill the hummer route, reroute for the bridge pup, drill everything, and that will be the end of the body work. Hoping for a good neck. I'm thinking about finishes, LPB with mint, surf green with tort and olympic white with parchment are high on the list...
I could buy a new body, but what's the fun in that?
If all goes well, this will be very close to vintage spec (Sorry Cagey).
