Aaaand... here it is! My first Warmoth Strat. Even though I've ran into some problems while building this Strat (more later in this post), the result is... well, let's put it this way.. I was making this kind of noises after pluging it into amp: OMG! @#$@#$%$@ @#$%@#$@1SFDGB#@!!! :headbang1: :headbang:
This thing put my other guitars into shame. The sustain, the overall sound... yummie!
Photos
Neck after sanding with 2000 grit - super slick!!
Neck specs
Construction: Warmoth Pro
Neck Wood: Pau Ferro
Fingerboard Wood: Ebony (Black)
Nut Width: 1-11/16"
Back Shape: Standard thin
Fret Size: SS6150 (Stainless)
Pre-Cut Installed String Nut: Earvana GraphTech White TUSQ
Inlays: No Inlay, Side Dots Only
Side Dots: Mother Of Pearl Side Dots
Body specs
Showcase Body
Quilt Maple on Alder, Rear Rout
Bridge: Wilkinson Tremolo
Jack Rout: 3/4" (19mm) Side Jack Hole
Tummy Cut, Forearm Contour, Contoured Heel
Top Finish: Brown to Clear Burst
Back Finish: Transparent Brown
Hardware
Dimarzio Transition humbuckers (Lukather Set) - definitely my new favorite ones!! Simply Amazing!!
Dimarzio Area 67
Tremol-No
The Color - A bit of a sad story
The color specs of a body are not mistake, as this is how body looked out of a box:
Unfortunately the brown laquer layer the base coat was not rough enough for the paint to make a molecular bond (that's what Warmoth said) and it started to come off. I was able to easily peel off the whole layer leaving the base clear exposed. I like the wood, so I didn't want to return it. I got my refund, buffed the base clear and now I have super nice natural finish, so no biggie! You might not agree with me, but I like better how it looks now.
Acknowledgements
Thank you all, who kindly answered all my questions while I was trying to figure out what is best for me. This forum and it's members rocks. Really you add great value to Warmoth itself. Seriously I vote that Hero Members and up should get paid from Warmoth.
Photos
Neck specs
Nut Width: 1-11/16"
Body specs
Showcase Body
Hardware
Dimarzio Area 67
Tremol-No
Acknowledgements
