No pic at the moment, but .... the all encompassing summer project of an engine top end overhaul on the Harley is complete, since I turned on the fuel supply, gave it one twist to prime the dry bowl, two more to get some fuel in the throat of the manifold, and hit the switch. Instant catch, no hiccup, no nothin... just like it never got torn down, except for a little smoke from all the assembly lube I used (lots). Four short run heat cycles later... and I noticed the choke cable plastic connector split. Other than that, she's ready to ride once I get the tank bolted down.
Thats a $1300 job, that cost me about $350, including all the special tools for headwork and cylinder work. I can see the thou' for labor at a shop. Its time intensive if done with care.
Now I can get back to guitars..... Guitar-Electronics sent me an email, the parts I've had on backorder since March are finally in. Just in time!
