Excellent - lush, complex, nice depth. AND, again I find that I like the sound of my guitar simply plugged into your stomp & both verbs off. It's sweeter -
Noise floor is practically zero. Yet the top end is there! Even my Variax single coil-out of-phase Strat model came thru in all it's brittle glory.
Really like the micro switches with the short throw bats. More robust & less likely to switch accidentally. Suggest that, cosmetically, it would look better if you used the 2nd offset barrel nut so the shaft is just peeking out.
Maybe 2nd generation you should consider DIP switch banks accessible thru a slot hole bc these switches will be set once & never touched again by most of the players. And DIP switch's are economical as well
Silk screen - I assume there are cost implications ... it would be less cluttered if you had the 1/4" + PS i/o labels on the front face. Not a killer.
The 9v 2.5mm connector. Ya, cost & part alignment registration but it would look better if the hole was better shaped/aligned. Not a killer.
At one point I did overdrive the input a tad & the digital hash was unpleasant. I wonder if you could incorporate some sort of gain-staging management in your designs. I mean, I know what I'm doing and recover quickly from whoooopppps moments but I wonder about newbies.
And last - the ambient music market should resonate with this design.
Didn't try it in stereo mode - but will if you can hold off until Sunday to pick it up.
Hey! I met Wormbot at the Drummonville show! I have to say that he's such a good player he made all the pedals sound great.
