Jumble Jumble
So this is a Vintage White chambered swamp ash body from Warmoth, going together with a Fender rosewood on maple neck I've had about 10 years from new. The body from that Fender Tele is destined for a new neck some day.
The Fender neck already has Sperzels on it, they've been there for years.
This is the current state of the body:
That's copper shielding with blue painters tape over it in the cavity there. Also the ferrules are in.
It's getting SD pickups - a nickel-covered '59 in the neck and a Little 59 in the bridge. I'm doing a superswitch 5-way wiring to get:
Neck humbucker
Neck split + bridge split (parallel)
Neck humbucker + bridge humbucker
Neck split + bridge split (series)
Bridge humbucker
When the neck is split, it'll be to the screw coil, but when the bridge is split, it'll be to the "slug" coil (the North). So it'll be hum cancelling in all positions. This also gives me the advantage of the fact that I'll be splitting the neck pickup to the coil that's in the 24th fret location.
I'm also putting a treble bleed on the volume control.
The wiring diagram for this is as follows:
However, I was a little concerned about the amount of awkward point-to-point wiring going on when adding the treble bleed stuff, so I designed this little breadboard:
So this resulted in the wiring looking like this:
I think I just have another jumper to add to the switch, and then the harness will be ready to have the pickups put in.
To complete this instrument I'm just waiting on delivery of a stainless steel 3-saddle bridge that's going in there. I think after that I have everything. I have a tort guard for now but I'm considering other options in the back of my mind.
Neck humbucker
Bridge humbucker
