EVH_5150
Maybe I’m missing something obvious but this doesn’t look right. The shaft of the 2 shortest tuners are barely long enough, and the string holes aren’t even visible. I have only tightened them snugly by hand with a 10mm socket, but I don’t think adding any more compression will help??? If I over-tighten them and they show signs of being “installed” they are not returnable. I removed the UMP plate and rechecked but it’s not that much better, and to be honest the UMP concept is the whole reason I chose this brand. Many of you are using these exact Hipshot tuners so I'm confused. This is a Strat conversion neck, btw, so is there a difference in headstock thickness to the other Warmoth models? These tuners range from 19 to 21 mm in height.
