Neck
Roasted curly/flame maple neck and fretboard
Gibson Conversion - 24.75” Scale
1-11/16th nut width
10-16” compound radius
Standard thin profile (slim C I believe?)
Compensated nut
Staggered Graphtech Ratio tuners
22 Stainless Steel 6115 frets
Body
Roasted Swamp Ash in Sonic Blue
Bareknuckle Mule bridge
Bareknuckle Apache Middle with zinc baseplate
Bareknuckle Apache Neck with zinc baseplate
Electrosocket input
Contoured neck heel
Master volume
Tone control 1 - variable treble bleed
Tone control 2 - master tone control
5 way switch
Super-vee Bladerunner trem
Weight - roughly 6.8lbs/3kg
Really sad to let this one go as it has been my number one workhorse for the past 3 years. Super versatile and it does have a few dings, but considering the amount of use it has had, it is in very good cosmetic condition… but that’s real world relicing…right?
These are around the edges/back, the front is clean. The vol and tone plastics are somewhat tarnished through use, probably just need a wipe or can be easily replaced.
Lovely Warmoth neck and body, expertly put together for me by my tech. The fretwork is exceptional and it currently has 11s on in, but they feel like 10s thanks to the reduced scale length and the contoured heel makes a noticeable difference for upper fret access.
HSS configuration is incredibly versatile, all those Strat tones are here (well, apart from the bridge single coil for obvious reasons…) which is further aided by a variable treble bleed (1st tone control). The trem is reassuringly weighty in use and tuning is rock solid thanks to the well cut nut and the Ratio tuners are great. The volume control is slightly further from the bridge pickup to make it easier to use.
Comes with a used Mono Sleeve gig bag.
£1,500 - I'm based in the UK so I would prefer a UK sale. I could consider shipping overseas but that's at the buyers expense and risk.
Cheers
1-11/16th nut width
Compensated nut
Body
Electrosocket input
Contoured neck heel
Master volume
5 way switch
Cheers
