GK Build-Your-Own-Combo : Porting Questions
  • Thread starter Thread starter whyachi
  • Start date Start date
if you go by the calculator the best box is a bit bigger than the bass bomb and the port is 10.5in, if you build the box at less than 6 cubic feet internal you'll want to go longer on the ports
sorry the above is for 4 ports per speaker. for 4 ports it says 4.1 inches which doesn't add up to what i said earlier, i guess i could have been wrong. at 8 cubic feet you are down to 2.7 inches port length
Hey you two, step back and take a breath, forget all the port lengths and diameter and math stuff, Your not gonna launch it into space......Are you?
Build one and plug it in and see how it sounds, Just cut holes for now, you can add sound tubes later
:doh:
Got caught up in the moment. The moment involved thirteen cups of coffee and access to the internet.
Sorry for the full page of back-and-forth convos. Will try to take it to PM's next time, sorry.
Don't do that then we can't read it.
Also true.
So I guess I'm taking a decent idea and some determination and laying into a stack of plywood and wires and I'll let you know if it sounds good when I'm done. Oh, and yes,
There Will Be Pictures.
