Fidelitrons on Warmoth
guitark
I did a search but could not find any information on this.  I just purchased a Warmoth Cabronita body that is on its way.  I have a set of Fender fidelitron pickups that I planned to use in it.  Now I am not sure if these will fit the pickup routes on the Cabronita.  The route is for TV Jones.  Has anyone put fidelitrons on a Warmouth Cab?
The last post here suggests that the no ears version should be close enough. Also, there's some possibly useful info about fitting them.
Thanks.  I had read that post.  My big question is will the fidelitrons fit in a Wamouth body that has been routed for TV Jones pickups.  Was hoping that somebody had build a Wamouth cab with fidelitrons.
I love TV Jones pickups.  If you go to the TV Jones website, there are a couple pages that give the dimensions of all their pickups.  They can be found below...
http://www.tvjones.com/pickup-and-ring-dimensions.html
http://www.tvjones.com/tech-specs.html
If you compare the TV Jones specks with the Fidelitrons, you should be able to find your answer.  Worst case scenario, a simple phone call will put you in contact with someone that can be more definite about your needs.
Good luck &  :rock-on:
